93 GC 5.2L crankshaft removal - JeepForum.com
post #1 of 2 Old 08-03-2009, 11:29 AM Thread Starter
va2ir
My buddy down the way has a 93 GC with the 5.2L 318 motor. He spun a rod bearing, the rod on number 1 cylinder broke and the engine stopped. Its been examined with a camera, and there is no other damage. After the broken parts were removed, the engine turns easily by hand. Last night we pulled the timing gears off with the chain, and now the crank is ready to drop. He wants to change it for a new one incase the old one got bent.
Question: Does the tranny (auto) have to come off? A local tekkie says the trans can stay on.
Has anyone done a crank removal and re-install on this motor? What is the procedure? he has the Haynes book which is almost useless.
Thanks
Ian R.
va2ir is offline
post #2 of 2 Old 08-03-2009, 11:40 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I can't think of a way to remove the crank-to-flexplate bolts without removing the transmission.
I've only removed the crank with the motor out. With the timing chain already out, just remove the rod and main caps and the crank comes straight out. Putting it back is more of a challenge due to lining up the rods with the crank. Cover the rod bolts with plastic tubing to protect the crank.
HighLonesome is offline
i just replaced my crankshaft-now i have a ? oops-sorry ZJ Grand Cherokee Forum 2 02-01-2009 06:11 PM
258 crankshaft and what else to drop in my 4.0? the88thpianoman ZJ Grand Cherokee Forum 6 09-15-2008 12:40 AM
ECU? Crankshaft Sensor? 93ZJV-8 ZJ Grand Cherokee Forum 7 07-14-2008 04:48 PM
crankshaft sensor tyler2 ZJ Grand Cherokee Forum 3 08-18-2005 07:40 PM
Crankshaft Pulley '94Jeepster ZJ Grand Cherokee Forum 1 12-03-2004 02:33 PM
