93 to 96 Engine swap. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 93 to 96 Engine swap.
New Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition CoiEnjoy 5% off in April 1997-2006 Jeep Wrangler Door Weather
Unread 04-19-2015, 02:17 PM   #1
skit6x
Can I swap a 318 and tranny from a 93 Grand Cherokee Laredo to a 96 Grand Cherokee Laredo?
skit6x is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 02:48 PM   #2
kachink
I haven't had direct experience with this, but it's my understanding that you can swap an ODBI (93-95) engine to an ODBII (96-98) ZJ, but you need to use all the sensors, etc from the later engine. Transmission is going to be a different story. 93 is going to have a 46RH hydraulically controlled transmission, which I believe has a separate TCM, where the 96 transmission is controlled by the PCM, which is going to be expecting a 44RE, electrically controlled transmission.
I'm sure someone else more knowledgeable will chime in, but I don't the transmission swap would be simple.
kachink is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 03:13 PM   #3
skit6x
Thanks for the information. Sounds like it would require plenty of work.
Unread 04-19-2015, 04:06 PM   #4
Taz360ZJ
yeah you can long block the '93 engine, and use it in the '96, the trans will not exactly swap over. the RH series is hydraulically controlled and the OD is separately controlled, and the RE series is electronically controlled. plus the RH is longer anyway, you would need the shafts, etc. it will cause all sorts if mayhem with the computer trying to find the trans.
Slate 5.9 Limited 8"/ARB/IRO/KOR/OME/231
White 5.9 Limited stock/231/30's
'93 ZJ SE 5.9 clone
Taz360ZJ is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 04:15 PM   #5
MurdaJs
Pretty much right on ^
In addition, to put the 46rh in the 96 you would have to treat the trans like a manual trans, PCM wise. Either sct $$$ or dodge manual trans PCM from a 96 ram or maybe dakota. Then you'll need a separate tcm for the 46rh, I don't believe they are cheap either.
96 SCT tuned 5.2, NV3500, 231, Hp30 TrueTrac 3-link, 8.8 Lokka Double Tri 4-link, Coilovers
98 5.9
MurdaJs is offline   Reply With Quote Quick reply to this message
Unread 04-19-2015, 09:54 PM   #6
dflewelling
The engine would be easy. I did the reverse half of what you're pondering. I took a 96 318 and put it in my 95 just ditched the obdII sensors. The 46Rh has no tcm, the only electronically controlled function is the torque converter lockup, and that's controlled by the PCM. The rest is all hydraulic pressure controlled.The 46rh is a good transmission, but you'd require modifications to make it work.
dflewelling is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 02:42 PM   #7
skit6x
I'm just going to rebuild my i6. Too good of a motor to switch. Hard to believe I made it drop a piston. Tough old motors.
