93 5.2L transmission fluid question - JeepForum.com
post #1 of 4 Old 07-20-2009, 10:48 AM Thread Starter
ubu
I checked the FAQ and searched, but couldn't find my answer right away. Quick question, I think.
I dropped the tranny pan and changed the fluid and filter. I added 5 quarts total and it reads low in neutral after driving 25 miles this morning. The manual says to add 4 quarts. I'm just wondering how much fluid is typically added after a filter change. Checking in park (like my Chilton's manual says) it reads fine. But, I guess it's actually supposed to be checked in neutral. I really don't want to overfill the thing and kill it. It has a cooler, if that makes a difference.
ubu is offline
post #2 of 4 Old 07-20-2009, 11:07 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
read in "n".
a pan drop will take anywhere from 4-7 quarts. start with 4 and keep checking till you get to the full line when following proper check procedure. (hot, in neutral, on a level surface.)
ratmonkey is offline
post #3 of 4 Old 07-20-2009, 11:55 AM Thread Starter
ubu
Thanks. I'm not so nervous now.
ubu is offline
post #4 of 4 Old 07-20-2009, 03:09 PM
npzj
i just serviced mine and it took 7.5 quarts.
npzj is offline
Transmission Fluid Change Question malibubts ZJ Grand Cherokee Forum 3 08-30-2009 06:50 PM
transmission fluid question? elmer_fud ZJ Grand Cherokee Forum 2 06-21-2008 08:53 PM
04 Transmission fluid change question... WoodiE55 ZJ Grand Cherokee Forum 9 05-10-2007 09:29 AM
Transmission fluid change question Stuart ZJ Grand Cherokee Forum 4 02-24-2006 06:30 AM
Transmission Fluid Question cdempsey ZJ Grand Cherokee Forum 2 07-18-2002 08:59 PM
