93 5.2 Shaking on Startup - JeepForum.com
post #1 of 4 Old 08-29-2012, 05:04 PM Thread Starter
Lakoswolf
Greetings everyone,
For a while I've been chasing an on again off again problem with my Jeep 93, 5.2L 141k miles. From time to time it will struggle to start and shake aggressively, after driving it for a little while it'll smooth out. Sometimes it will repeat on the next start and other times it won't. This happens regardless of AC usage So far I have:
Replaced spark plugs, wires and distributor cap.
Replaced Fuel Filter
Changed out the engine oil and replaced the filter
Made sure the air intake hose from the air filter is firmly attached to the engine.
I do not believe this is death wobble as you do not have to be driving for this symptom to occur.
Any input would be greatly appreciated, thanks in Advance!
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #2 of 4 Old 08-29-2012, 07:44 PM
Myusername1674
Hmm, might have something to do with exhaust?
Check your o2 sensor?
Try seafoaming the engine?
Run some lucos oil through the fuel?
Maybe doin' that may help
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 4 Old 08-29-2012, 09:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Fuel pressure check?
Compression?
Engine mounts?
ratmonkey is offline
post #4 of 4 Old 09-09-2012, 10:57 PM Thread Starter
Lakoswolf
Thanks for your suggestions guys!
5.2l , shake , start , zj
Mysterious Startup? NewJeepFever ZJ Grand Cherokee Forum 3 12-24-2008 03:05 PM
Check Engine, Jeep Shaking on Startup venterminator ZJ Grand Cherokee Forum 4 04-27-2007 07:34 PM
Startup Question Ex-Repoman ZJ Grand Cherokee Forum 10 11-07-2005 03:50 PM
Startup after sitting for 6 mo? Peter ZJ Grand Cherokee Forum 4 10-11-2005 08:30 PM
hi rev on startup sharpe84te ZJ Grand Cherokee Forum 4 08-19-2004 01:41 AM
