'93 4.0L-- idles at 1700 rpm! - JeepForum.com
post #1 of 4 Old 03-05-2004, 07:27 PM Thread Starter
Choff
Recently I replaced the O2 sensor on it, and cleaned a sensor in the throttle body (held in by two torx screws, had a black rod with a silver tip on it, not sure what it was, but it was nasty). Since I did that, it's been idling at 1700 rpm! Needless to say, this is damn hard on the tranny when putting it into gear.
Any ideas as to what could be causing this? It was running way rich with the old O2 sensor and was idling about 1500.
Thanks
CHris
Choff is offline
post #2 of 4 Old 03-05-2004, 10:17 PM
Saleen4971
did you try disconnecting the IAC connector, adn starting it? waht then? (the IAC is the one that you cleaned, i think)
1998 5.9 Limited
ET: 14.3@94MPH
Engine/Trans
- Full Kolak Exhaust (ML's FM70) - FIPK2 - APS 52mm TB - MSD Blaster SS - A3923's - Magnecor's - MP ECU - 180 robertshaw t-stat - Relocated IAT - E.H. M1 - B&M Trans Cooler
Susupension/Brakes
- Addco 1.25" Military front & 7/8" rear sways - Edelbrock IAS shocks - OME S.S - Stilens Front & Rear
Coming Soon :
Level10 Stage 3 46RE - WJ knuckle conversion
Saleen4971 is offline
post #3 of 4 Old 03-06-2004, 09:12 AM
MikeRuth
I postec on a different subject about idle, but disconnect the battery for 1 hour, then reconnect and drive the car a few miles. Should come back to normal.
MikeRuth is offline
post #4 of 4 Old 03-11-2004, 02:40 PM
KyleM
Thanks
CHris
Sounds like the IAC (the part you cleaned) is stuck and/or dead.
KyleM is offline
95 ZJ Idles at 0 RPM AEagle326 ZJ Grand Cherokee Forum 3 07-24-2009 07:34 PM
extreme vibrations @ 1700-2300 RPM expandedvision ZJ Grand Cherokee Forum 4 01-07-2009 09:23 PM
'94 GC Idles Badly compugeek ZJ Grand Cherokee Forum 5 07-08-2008 12:12 PM
2000 GC idles up and down..... StickinMud ZJ Grand Cherokee Forum 9 04-24-2007 09:43 PM
idles down then quits nursematt ZJ Grand Cherokee Forum 1 11-07-2006 10:41 AM
