93 4.0 GC - No Spark - JeepForum.com
post #1 of 4 Old 11-18-2007, 01:22 PM Thread Starter
Rockdaddy
1993 XJ Cherokee
Iím having a problem with my 93 4.0 GC 107K miles, not starting/dieing on the road at times; the control module/brain on the firewall has already been replaced.
Iíve found when it doesnít start; it has no spark.
Checking for voltage at the 2 wires at the coil I have no voltage with the ignition on or cranking. Could the problem be with the crankcase positioning sensor?
Rockdaddy is offline
post #2 of 4 Old 11-20-2007, 06:55 PM
greasefingers
greasefingers's Avatar
1994 ZJ
The CPS crank shaft position sensor is notorious for causing stalling and engine no-start issues.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 4 Old 11-20-2007, 07:02 PM
John in MA
1994 ZJ
What he said. You're not a 4.0 Jeep owner until that thing dies. I did mine with a couple long extensions without even jacking the truck up, easy fix. Get the dealer part and make sure you get the cardboard spacer, too.
Oh yeah, before you run out and spend money, pull the codes. Just in case.
John in MA is offline
post #4 of 4 Old 11-20-2007, 08:46 PM
greasefingers
1994 ZJ
So John Ö how many times have you asked people to pull the codes lately?
It is always a good start to pull the codes first (found in the FAQ section) and make sure that the battery is up to snuff, when trouble-shooting electrical issues. These two may not get you anywhere but at least you are being pro-active about your method-for-madness.
Cheers Steve
no spark to spark plugs??? jeepgcnp ZJ Grand Cherokee Forum 4 11-27-2011 10:08 PM
spark @ coil, no spark @ plugs 94GC52 ZJ Grand Cherokee Forum 4 07-09-2009 07:17 PM
v8 5.9L spark gap tony4704 ZJ Grand Cherokee Forum 1 11-08-2008 03:14 PM
No spark.......97 4.0 PDshooter ZJ Grand Cherokee Forum 3 09-05-2008 07:18 PM
need help with 93 gc no spark dn9979 ZJ Grand Cherokee Forum 17 04-10-2007 04:59 PM
