92 Dodge 5.2 and interchangeability? - JeepForum.com
post #1 of 22 Old 11-05-2010, 08:12 AM Thread Starter
xj BMX xj
1992 XJ Cherokee
I have a 1992 Dodge Ramcharger thats ive been trying to sell but thiss weekend im picking up a 96 v8 Orivis with 180k on it, or a 95 limited v8 i was wonderin if i could just pull the Rams drivetrain to keep for parts and rebuild the motor it to swap in when the stock one dies? or is it too much of a pain to make it work?
92 Cherokee Trail toy. - 97 Cherokee Street toy.
XJcruiser: Crumple zones? I guess the other car will have to share those.
xj BMX xj is offline
post #2 of 22 Old 11-05-2010, 09:59 AM
ZombieJeep93
Dodge and Jeep 5.2 are the same. Trans case is diff due to starter location.
93 Grand Wagoneer (de-wooded) 5.2 Mag, 2"BB, Magnaflo Cat, Gibson ex, K&N CAI, Mopar pcm, 32" BFG AT, Accel truck ignition
ZombieJeep93 is offline
post #3 of 22 Old 11-05-2010, 10:39 AM
CatSplat
1994 ZJ
The motor should be functionally identical, however the transmission will not fit due to the reversed starter location. Transfer case may swap over as well if you need it, depending on output shaft length and model.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #4 of 22 Old 11-05-2010, 11:32 AM Thread Starter
xj BMX xj
1992 XJ Cherokee
well cool, looks like my truck is off the market
post #5 of 22 Old 11-05-2010, 12:11 PM
sls001
1997 XJ Cherokee
The transfer case (if stock) is probably going to be a NP208 with a pass side drop..these are full time 4x4 boxes
1997 XJ - Parts Donor - Good Running 4.0, HP30
1997 ZJ - Parts Recipient - Trashed 4.0
1988 Dodge Ram - D60's, 4.56, ARB's, 408 cu.in, 46RH, NW-Fab Black-Box\205, BFG AT 35"s
sls001 is offline
post #6 of 22 Old 11-05-2010, 12:27 PM Thread Starter
xj BMX xj
1992 XJ Cherokee
nope its an np-241 part time, may be a good swap for the 249?
post #7 of 22 Old 11-05-2010, 12:29 PM
sls001
1997 XJ Cherokee
Anything wrong with the RamCharger...if you are looking to sell it even without the drive line you can post it over on RamChargerCentral
sls001 is offline
post #8 of 22 Old 11-05-2010, 12:53 PM Thread Starter
xj BMX xj
1992 XJ Cherokee
it needs new rear gears, and is prety rustedi posted it there and had little interest, i thinkfue to my location, not alot of RC fans in Mi.
post #9 of 22 Old 11-05-2010, 02:09 PM
ZJ5point2GCL
i think they have different cams
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #10 of 22 Old 11-05-2010, 04:28 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Didn't the Ramcharger have the LA motor?
If so, not gonna swap easily into a ZJ.
Keeps the varmints on the run, boy
HighLonesome is offline
post #11 of 22 Old 11-05-2010, 04:58 PM Thread Starter
xj BMX xj
1992 XJ Cherokee
They were till 92 (mine) they then got a Magnum MPI 318 and LA TBI 360, 93 both 318 and 360 were Magnum.
Diff cams eh? this is interesting ill have look more into this. Any idea witch would produce more power?
post #12 of 22 Old 11-05-2010, 06:03 PM
ZJ5point2GCL
I believe the jeeps do, i could be confusing something here though, but iam pretty sure the jeeps have hotter cams
post #13 of 22 Old 11-05-2010, 06:50 PM
CatSplat
1994 ZJ
Considering the only difference in power between the Jeep and Dodge is 5HP and 5lb-ft (~2% difference), I doubt it's the cam. The difference can likely be attributed to the different exhaust manifold designs. I've never seen documentation proving the Jeep cams have different part numbers. I'm going to see if I can track down the Dodge part numbers for the cams and see if they match.
The Jeep of Theseus
CatSplat is offline
post #14 of 22 Old 11-05-2010, 07:36 PM
CatSplat
1994 ZJ
OK, here's what I've discovered so far:
1993 - 1994 Jeep 5.2L Cam Part# 5300-6707
1995 - 1998 Jeep 5.2L Cam Part# 5302-0283
1992 - 1993 Dodge Ram 5.2L Cam Part# 5300-6707
1994 - 2001 Dodge Ram 5.2L Cam Part# 5302-0283
1998 Jeep 5.9L Cam Part # 5302-1101
1993 - 1997 Dodge Ram 5.9L Cam part# 5300-6708
1998 - 2002 Dodge Ram 5.9L Cam part# 5302-1101
Unfortunately, I can't find specs for those cams to show a distinction between the two varieties of cams for each engine, but with the exception of 1994 it seems the Jeeps had the identical cam as the same model-year Dodge. That also helps dispel the myth that the 5.9 Jeep had a hotter cam than the equivalent '98 Ram.
The Jeep of Theseus
CatSplat is offline
post #15 of 22 Old 11-05-2010, 09:02 PM Thread Starter
xj BMX xj
1992 XJ Cherokee
wow good *** info, thank you.
cladding interchangeability BlackDaddyZJ ZJ Grand Cherokee Forum 2 05-17-2010 07:35 PM
4.7 N code - interchangeability Shiprekd ZJ Grand Cherokee Forum 3 07-09-2009 11:58 AM
Interchangeability between ZJ and XJ blackjack12982 ZJ Grand Cherokee Forum 0 04-23-2009 08:45 PM
Need help with Control Arm interchangeability, is ZJ same as TJ ???? Mark T ZJ Grand Cherokee Forum 11 01-13-2006 05:42 PM
Interchangeability of parts... Brian's 97 ZJ ZJ Grand Cherokee Forum 1 03-25-2005 09:50 PM
