90/136 amps - JeepForum.com
post #1 of 7 Old 08-15-2011, 02:25 PM Thread Starter
jaguarjoe
90/136 amps
Will a 136a alt from a 98 5.2 bolt into my 95 5.2? 46a more current is a lot to gain.
Other than a fatter feed wire and maybe a bigger fuse, what else is there?
Will this piss off the PCM? Or should I just use an external regulator?
jaguarjoe is offline
post #2 of 7 Old 08-15-2011, 02:42 PM
Timbone1343
I would like to know about this too. I want to upgrade my ALT for my sound system.. Will the pcm be able to handle the higher amps or will it burn out?
Timbone1343 is offline
post #3 of 7 Old 08-15-2011, 02:54 PM
sebian
It should just be a direct swap without having to add an external regulator, or changing the wiring.
PCM will still regulate the system without problems, you will just have more amperage to hook up more toys.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #4 of 7 Old 08-15-2011, 03:01 PM
Timbone1343
Thanks!, And I would park is those Go Green spots if it were me..
1997 ZJ 4.0 I6 My DD, Pretty much stock. 242,XXX miles 8-15-11
post #5 of 7 Old 08-15-2011, 03:15 PM
Craft95ZJ
1986 MJ Comanche
Its a direct swap, I did this on my 95. No problems no new fuses or bigger gauge wires needed.
Daily driver '01 TJ 3" RC lift
'86 MJ 3.4L interior rebuild in progress.
Craft95ZJ is offline
post #6 of 7 Old 08-15-2011, 04:17 PM Thread Starter
jaguarjoe
That's waaay too cool! With 136a I can ditch the mechanical fan and put in a Taurus fan.
What's the deal with the Taurus fan sucking down the system when it kicks on? A soft start circuit would not be hard to whip up and wouldn't be expensive. 1 wire in, 1 wire out, and a gnd.
Then I can polish the headlight lenses and pop in some flame thrower lamps.
Does the GC headlamp circuit handle 100w lamps? Or are relays in order.
I know my F150 balked at bigger lamps. Every stinkin wire in that thing is sized to the absolute minimum.
post #7 of 7 Old 08-15-2011, 04:23 PM
Timbone1343
Anything to save a penny.
Stock Alterntor Amps ALombardi WK Grand Cherokee & XK Commander Forum 2 01-24-2010 04:12 PM
can you have 2 factory amps? grand95zj ZJ Grand Cherokee Forum 9 11-21-2009 11:34 AM
40 Amps ASD fuse keep blowing Hamid ZJ Grand Cherokee Forum 1 11-13-2009 12:54 PM
Alternator Amps, how could you tel? Hamid ZJ Grand Cherokee Forum 10 07-05-2009 02:37 AM
Stereo Q: Where did you mounts your amps Laid-Off ZJ Grand Cherokee Forum 5 07-01-2008 08:43 PM
