87k miles on WJ. what maintenance/services should i perform? - JeepForum.com
post #1 of 7 Old 06-24-2006, 09:35 PM Thread Starter
kilabeez0
i've read about changing the oil in the diff. i've never done anything to the tranny, radiator or anything. what kind of maintenance should i do to the tranny? i dont have 2 grand to sink into a tranny and any preventative maintenance i can do i will.
kilabeez0 is offline
post #2 of 7 Old 06-25-2006, 10:03 AM Thread Starter
kilabeez0
anyone????
post #3 of 7 Old 06-25-2006, 10:14 AM
Varkyl
No where near stock
Varkyl's Avatar
Well at this point it is kinda touch and go with performing "preventative maintenance" on the tranny. If you have not had the tranny touched before, doing a service on it now may just kill it. It all depends on who you talk to on what answer you get on this. But if it were me I would change the fluid and filter and hope for the best.
Nathan
One slightly modified '96 ZJ
new sig coming soon
Varkyl is offline
post #4 of 7 Old 06-25-2006, 10:27 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
What kind of symptoms are you experiencing?
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 7 Old 06-25-2006, 11:40 AM
mrjeep
My personal feeling is better late than never. I just hit 87,000 on my 99 GC. I purchased the car off lease with 36,000 on it. I changed the tranny fluid and filter at around 70,000 and the differentials at around 65,000. If you have not done these two things, I would recommend doing it now. I'm about to change the transfer case fluid in the next few weeks. You also need to change the brake fluid along with coolant if you have not done so. I also need to replace the CV joints as the boots have split open and change the rear tranny seal along with the front t/c seal. You may want to also check these seals as they wear out over time.
mrjeep is offline
post #6 of 7 Old 06-25-2006, 09:10 PM Thread Starter
kilabeez0
Hunter
none, occasionally if i mash the gas getting on the highway or passing someone it will shift irratically for a second and then drop to like first gear and fly!
post #7 of 7 Old 06-25-2006, 09:43 PM
99wjman
TRANSFER CASE because you wont have that vc problem i did mine and it fixed it my tc fluid was black now it is like a dream
1999 Grand Cherokee Limited
4.7l v8
FIPK 2
91k
Bridgestone dueler revos
99wjman is offline
Spark Plug Maintenance Schedule, miles or time? AdamJ ZJ Grand Cherokee Forum 1 03-14-2009 12:06 PM
How much for dealer services? TAWS600 ZJ Grand Cherokee Forum 9 12-06-2007 12:38 PM
70,000 mile services? journey1381 WJ Grand Cherokee Forum 4 07-26-2007 07:02 PM
BG Services CaliforniaJeep ZJ Grand Cherokee Forum 5 02-12-2005 02:56 AM
Resetting Miles Until Maintenance Display Meerkat ZJ Grand Cherokee Forum 0 10-17-2004 07:51 AM
