Quantcast 8.8 swap? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 8.8 swap?
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 10-22-2008, 03:37 PM   #1
dank10
8.8 swap?
hey guys im new to the forum i have a 97 zj. im also into mustangs so i have an 8.8 out of an 1991 mustang laying around. i was wondering if this would be ok to use for the swap or not? thank you dan
dank10 is offline   Reply With Quote
Old 10-22-2008, 04:17 PM   #2
spidermonkey
No sir, that won't work. What you want is a 95 up Exlorer or Mountaineer 2 or 4wd. They have disc brakes, 31 splines and are only slightly narrower than the ZJ axles. You can find them in 3.73, 3.55, and 4.10 gears with or withought a limited slip. They also have the right bolt pattern. While your at the junk yard get a driveshaft flange from a ranger so the ZJ shaft will work. The ZJ has a 1310 U-joint and the ford is a 1330, or get a U-joint that has both. Then a quality welder so nothing falls off when your done.
98ZJ, 4.0,242, 8.8 Detriot, hp30, 4.56's
My build here: http://www.jeepforum.com/forum/f197/spidermonkeys-98-zj-build-716209/
North Shore Wheelers www.nsw4x4.com
spidermonkey is offline   Reply With Quote
Old 03-16-2009, 12:58 PM   #3
theron_limited
Quick question...
...Why won't the Mustang 8.8 work?
theron_limited is offline   Reply With Quote
Old 03-16-2009, 02:08 PM   #4
spidermonkey
There are lots of 8.8s out there, Mustang, F150, Ranger, Crown Vic, but the only one the correct width is the Explorer/Mountaineer variety. It ends up about 5/8" per side narrower than the ZJ axle.
My build here: http://www.jeepforum.com/forum/showthread.php?t=716209
Old 03-16-2009, 02:39 PM   #5
UTChavok
Originally Posted by theron_limited View Post
Quick question...
The mustang 8.8 is basically the same level as the D35, I believe its 27 spline, and wouldnt be nearly worth the work of putting it in.
UTChavok is offline   Reply With Quote
Old 03-16-2009, 02:58 PM   #6
StrokedWJ
What are the specs on the mustang 8.8? WMS to WMS, spline count, and bolt pattern are the three big factors.
UT, I'm pretty sure the 8.8's are either 31 or 28 spline, but either way the shafts and housing are stronger than a D35. (Remember to weld the tubes to the diff on the 8.8's to prevent them from spinning). Obviously the 31 spline is stronger and more of an upgrade than the 28 spline version.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Click this -->Think you can beat me?
StrokedWJ is offline   Reply With Quote
Old 03-16-2009, 03:25 PM   #7
UTChavok
Yeah its 28 spline, I just couldnt remember exactly off the top of my head. The mustang 8.8 is 28 spline vs the explorer 31.
Glock Forum
