8.8 pinion angle(i know) - JeepForum.com
post #1 of 33 Old 07-04-2013, 07:56 AM Thread Starter
Kreeper
1994 ZJ
I have to ask because I have not seen this one answered yet,I'm ready to install the 8.8 for a test fit and to set pinion angle before final welding,I will be running my stock ds for a while till I can buy sye and dc driveshaft I have full adjustable long arms so what angle should I shoot for that will work for the mean time on a 5.5 lift.
Kreeper is offline
post #2 of 33 Old 07-04-2013, 09:42 AM
AlphaLorde
How long you going to run your stock ds?
If it were me I would set the pinion angle close to what it would be with the sye kit.
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #3 of 33 Old 07-04-2013, 02:01 PM Thread Starter
Kreeper
1994 ZJ
It'll be a while before I can justify spending more money(wife says I have to many parts laying around as is).im thinking with my lift I should be alright at 12* since its fully adjustable,but that's why I started this thread to get the pros opinions .
Kreeper is offline
post #4 of 33 Old 07-04-2013, 02:05 PM
Agent620
You will blow u joints and adapters if you don't stick to stock angle. Ask me how I know. Do the SYE now and set the right pinion angle. Or run stock shaft and stock angle. Nothing else, you also get a humming sound. Thats the U-joints saying they're unhappy.
Thanks to Anticanman who gave me a membership!
Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"
I pitty anyone who tries to reach into that netting unaware.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #5 of 33 Old 07-04-2013, 02:07 PM
WhiteOut
WhiteOut's Avatar
This isn't a TJ.
WhiteOut is offline
post #6 of 33 Old 07-04-2013, 03:05 PM Thread Starter
Kreeper
1994 ZJ
Indulge whiteout.
Kreeper is offline
post #7 of 33 Old 07-04-2013, 03:41 PM
riot1987
I went to about 13* when I did my 8.8. Not sure what the "exact" numbers should be. Isnt your pinion angle supposed to be an exact opposite match your T case output angle? Or maybe I read that wrong somewhere.. ZJ's have a longer wheel base (longer driveshafts) so driveline angles arent as severe as with say, a TJ
Build thread^^
riot1987 is offline
post #8 of 33 Old 07-04-2013, 03:46 PM Thread Starter
Kreeper
1994 ZJ
What driveshaft are you using riot?
Kreeper is offline
post #9 of 33 Old 07-04-2013, 05:25 PM
AlphaLorde
when using a conventional drive shaft the output angle at the tcase should match the input angle on the axle.
With a sye kit and using a dbl cardan driveshaft the pinion should be pointed right at the drive shaft
post #10 of 33 Old 07-04-2013, 05:50 PM Thread Starter
Kreeper
1994 ZJ
Well my wife won't be happy but that's easy to fix lol,I'm going to order a sye on fri from iro and I have a double cardon I can get for $30 and throw new joints in and that solves that,pinion will be at 15* per my angles so thanks for the help.
Kreeper is offline
post #11 of 33 Old 07-04-2013, 08:39 PM
AlphaLorde
Sounds about right.
post #12 of 33 Old 07-04-2013, 10:46 PM
JohnnyZJ
U making your own brackets? I had the IRO kit took an hour to weld up and the instructioms were super easy. Didnt even test fit: just welded it up and bolted it in fit perfect
07' JKUR rollin on 35s
JohnnyZJ is offline
post #13 of 33 Old 07-05-2013, 07:09 AM Thread Starter
Kreeper
1994 ZJ
I'm using the artec truss,perfect fit.
Kreeper is offline
post #14 of 33 Old 07-05-2013, 07:42 AM
OverlandZJ
Installing the SYE then checking your angle is the right way to go about it. Then you can set the coil buckets and tracbar bracket level..
I'm at 4.5" and will be installing an XJ D44 into my rig here soon. When I had the bracket kit installed I set the pinion at 10* and leveled the buckets, i'll probably be just a few degrees off.
OverlandZJ is offline
post #15 of 33 Old 07-05-2013, 07:59 AM Thread Starter
Kreeper
1994 ZJ
The coil buckets are 2 degrees forward and trackbar bracket is straight up.
Kreeper is offline
