8.8 brake calipers- will zj calipers go on an 8.8? - Page 2 - JeepForum.com
post #16 of 28 Old 09-26-2012, 07:43 PM
riot1987
My jeep is like a woman. Give me money. and more money ..and more money. AND MORE MONEY!!!!!!! Thanks for the input dudeskies
Build thread^^
riot1987 is offline
post #17 of 28 Old 09-27-2012, 10:47 AM
JohnnyZJ
Originally Posted by ratmonkey View Post
I guess you missed the bit about having to ream the bore out and drill the holes right.
I used the 44a backing plate/dust shield and the cast mount/slide piece from the 8.8 because it had smaller divots.
Used the zj calipers, ebrake, rotor, etc.
oh. that must have been a pain in the butt. i kind of figured thats what you did after i put this post in. i'm lazy and my times worth more than making crap work. took me 20 mins to pull brake plates off a junkyard axle, and i grabbed side gears and spare shafts for pewps and giggles. you didn't post that in this thread though I'm sure you've posted it numerous times.
to OP, if you're NOT a handy fabricator (like myself) i'd look for the Ford stuff; its not that expensive and it'll all bolt together nicely.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #18 of 28 Old 10-02-2012, 08:52 PM
riot1987
My ZJ calipers worked on a 97 exploder 8.8. Rotors too
Build thread^^
riot1987 is offline
post #19 of 28 Old 02-04-2013, 08:11 AM
KyBoy1991
I know this thread has been idle for a few months...but I just finally got mine 8.8 swapped in this past Saturday...
I was able to reuse my ZJ D35 Calipers, Rotors, & E-Brake Cables on the 8.8 from a 98 explorer. The 8.8 had some clip like things where the brake pads sit/slide...removed those because they wouldn't fit otherwise. And they were not on my D35, so figured it was a non essential and maybe only a smooth surface to allow sliding easier or just used for quieting any rattles. Eitherway, the pads do not touch there now, shouldn't be a problem, they fit, they work perfectly.
No need to replace the brakes on my 98 Limited.
KyBoy1991 is offline
post #20 of 28 Old 02-04-2013, 08:46 AM
riot1987
I didnt use the slider pieces on mine either.
Build thread^^
riot1987 is offline
post #21 of 28 Old 02-04-2013, 09:41 AM
Freestyle713
1994 ZJ
You might as well just get new calipers anyway. At advance, the core is worth almost the same price of the caliper, so in the end you're really only spending 5 or 10 bucks for a new (reman) caliper that you don't have to modify.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
post #22 of 28 Old 02-04-2013, 10:31 AM
KyBoy1991
While this may be true, there was NO mods to mine. that's the whole point here...the ZJ calipers mounted right up. No need to bleed brakes or deal with anything.....unbolt then rebolt to the new axle and drive away.
post #23 of 28 Old 02-04-2013, 12:42 PM
Freestyle713
1994 ZJ
Yeah, thats you though. It seems as if some people can swap theirs no problem, and others cant get them to work, like johnnyzj.
post #24 of 28 Old 02-04-2013, 01:41 PM
KyBoy1991
Maybe there is something that changed from the years of the jeep D35....not sure....most I've seen looks like the 96-98 D35 seems to bolt right up to the 96-98 explorer 8.8
Thank God I got lucky is all i can say.
post #25 of 28 Old 02-05-2013, 04:13 PM
plntman
if the 8.8 is stronger why do you need that big truss on the axle. I have the 8.8 under mine and the brakes that I just put on my 35 fit on the 8.8.
plntman is offline
post #26 of 28 Old 02-05-2013, 05:08 PM
riot1987
You gotta have brackets on the axle anyways and when I researched it, it was worth the little bit extra money for the complete truss.
Build thread^^
riot1987 is offline
post #27 of 28 Old 02-06-2013, 02:03 AM
MilanJeep
MilanJeep's Avatar
My Dana 35 rotors and calipers were a direct fit
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #28 of 28 Old 02-06-2013, 07:43 AM
KyBoy1991
Exactly what he said...I got one of the first runs of the Artec kit, and it was within $20 of the IRO bracket kit. Had I not received the huge discount, or just gotten lucky to find it, I would have went with a regular bracket kit and welded the tubes and called it good. Now this way, if I decided to get stupid later in life I know there's no way I will worry with that axle. It was just too good of a deal to pass up at the time....but if I had to buy them at this point I wouldn't have gone with the truss just because of money.
Teves calipers to Akebono calipers 2002WJHO WJ Grand Cherokee Forum 69 08-05-2012 01:13 PM
How do I know what brake calipers I have? gmp211 ZJ Grand Cherokee Forum 4 09-03-2009 11:07 AM
WJ Brake Calipers 01Limited45324 ZJ Grand Cherokee Forum 8 07-07-2009 09:19 PM
Brake calipers zaq123 ZJ Grand Cherokee Forum 3 09-26-2005 08:42 PM
How do I tell which brake calipers I have? askoop ZJ Grand Cherokee Forum 5 03-01-2005 01:59 AM
