7" of lift and rear sway bar isn't going to work - any ideas? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 7" of lift and rear sway bar isn't going to work - any ideas?
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 06-24-2012, 02:35 PM   #1
Area.3.Fiftyone
I'm just about done with the Long arm lift and ran into yet another problem today when I went to install the extended sway bar links.
Because of the amount of lift and moving my rear axle back, the geometry for the rear sway bar is just way off and I don't see any way to make it work other than heating it up and bending it.
My only other choice is to remove it altogether until I can get one from a TJ. They bolt to the axle so I've been told, and I would have to make some custom mounts on the sub frame side (which is no big deal).
Does anyone have any other ideas? I'm leaning towards just removing it for now but was wondering how that would make it handle in the rear? I know the factory one is pencil thin and probably doesn't do too much, but I was just wanting to hear from anyone that has removed it altogether and their impression on ride quality.
If you have any suggestions, please let me know.
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #666[/COLOR][/URL][/FONT][/SIZE][/COLOR][/COLOR]
[/CENTER]
79' CJ7
82' CJ8
94' YJ
96' ZJ
[i]Diagonally parked in a parallel universe........[/I]
Area.3.Fiftyone is offline   Reply With Quote
Unread 06-24-2012, 02:42 PM   #2
riot1987
PuRplE HAzE
riot1987's Avatar
I took mine out at 4" of lift and it doesn't ride too bad at all. i would suggest getting an addco front sway if you havent already.
riot1987 is offline   Reply With Quote
Unread 06-24-2012, 02:55 PM   #3
Kur
I've got the exact same issue on my ZJ at 7 inches. I even tried flipping the sway bar over, which helped the angle, but there is still no way to get the eye over my extended links. I am going to just remove it for now and see how it rides. If I decide I really need one, I'll probably go the TJ route. Besides, going with a TJ bar will also free up some space for the upper control arms on suspension compression.
Kur is offline   Reply With Quote
Unread 06-24-2012, 03:21 PM   #4
Area.3.Fiftyone
After doing some more research on the interweb, it seems like my best be to be able to re-use the factory bar is to heat it as close to the end as possible.
That way it doesn't effect the strength or properties of the bar too much. There is also less chance of failure when keeping it close to the eyes.
I'm going to have at it with the torch tomorrow. The plan is to only bend the last 2 inches so that the eyes are perpendicular to the links.
I'll post some pics when I'm done.
[/CENTER]
79' CJ7
82' CJ8
94' YJ
96' ZJ
Unread 06-24-2012, 04:39 PM   #5
FearTheEight24
No rear sway here I'm at 5.5" anything over 3.5" you shouldn't be throwing it into corners to cause body roll anyway
1996 ZebraJeep Limited 4.0l: 5.75" net lift (IRO, RC, ect...), 15x8 Procomp 7031s, 33x12.50x15 Cooper STTs, Skids and sliders, full exhaust, much more...
FearTheEight24 is offline   Reply With Quote
Unread 06-24-2012, 06:36 PM   #6
Technohead
Old school
Technohead's Avatar
The primary purpose of the rear sway bar is to fine tune oversteer of the stock suspension. If you consider that lift, long arms, larger tires, etc have completely changed the stock handling characteristics then its basically a waste of time to mess around with the rear sway bar.
Technohead is offline   Reply With Quote
Unread 06-24-2012, 06:57 PM   #7
biggoofy
Local *******
biggoofy's Avatar
6.5 and no sway bars here lol but mine doesn't see much highway. I plan to put in an anti rock after I can get up the funds.
Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
My Build
Need quality parts call Andy at Ironman4x4fab!!!!!
http://ironman4x4fab.com/index.html
biggoofy is offline   Reply With Quote
Unread 06-24-2012, 10:06 PM   #8
mr4x4
No rear sway bar for me either 5.5" lift
But I have the claytons high clearance brackets and with the long arms there's no place for it anyways
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline   Reply With Quote
Unread 06-24-2012, 11:52 PM   #9
ratmonkey
Living dead mod
ratmonkey's Avatar
Antirock and tj bar here. Definitely helps on road manners and is a vast improvement Offroad over disco'ing.
ratmonkey is offline   Reply With Quote
Unread 06-25-2012, 12:32 AM   #10
mr4x4
I want the antirock
Unread 06-25-2012, 02:10 PM   #11
BigClay
BigClay's Avatar
1994 ZJ
No sway bars here either, very little highway driving, and I would not want to make an emergency turn of the steering wheel on the road.
Not very fmailiar with the Antirock setup, how does it help offroad? Off camber situations?
Built 94 ZJ: Exo cage, waggy 44/8.8 axles, 4.88 gears, 35" PBRs - sold
Build thread
BigClay is offline   Reply With Quote
Unread 06-25-2012, 02:37 PM   #12
Area.3.Fiftyone
Well, I decided to keep my rear sway bar because this Jeep will see lots of daily driving on the roads.
I took a torch to the very ends of the bar, and bent it up slightly so that it was nearly parallel with the bracket on the axle.
It looks like it's going to work out well, and the heat was kept to as close to the end as possible so that the temper of the bar was not affected.
[/CENTER]
79' CJ7
82' CJ8
94' YJ
96' ZJ
Unread 06-25-2012, 02:44 PM   #13
gabrod72
Nice. I was going to use mine but it gave me more trouble than it's worth. I was able to get it installed but since I'm on an 8.8 with no spacers I was afraid of it moving and gashing a hole in one of my sidewalls. I'm at around 6.5" with no rear and I take it on the highway all the time. With my setup on 35"s, I couldn't tell any difference with or without it on. As for the front though, I can feel when that one's gone the first time I turn.
EDIT: Looking good there... You're going to appreciate the way it drives when it's all done. Oh, and the increased capabilities off road are sure to please as well.
_______________________________________________
WARNING: Lo barato sale caro (Cheap things often lead to more expense)
gabrod72 is offline   Reply With Quote
Unread 06-26-2012, 05:22 AM   #14
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I wish I could go outside and measure my rear swaybar links....but, I sold it. But, I did have longer links than it looks like you're running.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 06-26-2012, 07:05 AM   #15
Area.3.Fiftyone
Those were bought from IRO. I told them I was running 7 inches of lift and that is what they sent me.
They are quite a bit longer than the stock links.
In any case, I think it's going to be ok like that for now. I'll look into swapping in a TJ bar once I can source one.
[/CENTER]
79' CJ7
82' CJ8
94' YJ
96' ZJ
