7" IRO springs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 7" IRO springs
JEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! BroughNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 02-10-2015, 02:43 PM   #1
Dubfire98
7" IRO springs
So I do really like some of IROs stuff and I personally run a handful of it on my jeep. I was wanting to get a somewhat bigger lift spring and all i notice was there 3", 4.5", and 7". Right now i have what im guessing is some wore out 3.5" from the PO and i added a 2" bb lift to it. It sits about right but im wanting to do away with the bb lift and run all spring. Will a 7" really net 7" or will it actually squish a little? I have full IRO adj. shorties in rear and some old PO stuff up front. What should i do? Looking for around 5" with no bb lift.
TN JEEPER
Dubfire98 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 03:07 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
The IRO stuff is spec'd as it will work. 7" is a lot for short arms.
If you haven't trimmed your fenders give us a measurement from the center of the wheel to the fender lip. That will give you an idea of how much you are currently lifted. Stock is about 18".
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 02-10-2015, 05:09 PM   #3
Technohead
Old School
Technohead's Avatar
Rusty's has 5.5" springs which I would highly recommend.
Technohead is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 05:22 PM   #4
Dubfire98
Well I don't want 7" I just want around 5.5
Unread 02-10-2015, 06:05 PM   #5
Dubfire98
Ok so I'm at 23.5" from center of hub to bottom of fender
TN JEEPER
Unread 02-10-2015, 06:26 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
So you are actually at about 5.5"
The rusty's springs aren't a bad idea. You can PM kolak, he may have some options.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 02-10-2015, 06:32 PM   #7
rivera82
I ordered my 5.5" coils from iron rock, you have to call cause they are not listed online.
rivera82 is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 06:39 PM   #8
Dubfire98
Good info rivera82
TN JEEPER
Unread 02-10-2015, 08:27 PM   #9
AnotherRedZj
Is that front and back?
5.2 crate - fourwheelcustoms 2.25 BB - 31x10.50 BFG at-ko's 249/242 swap - front drive shaft upgrade by driveshaftspecialistincorporated - jcr off-road front bumper - engo 12k lbs winch......
AnotherRedZj is offline   Reply With Quote Quick reply to this message
Unread 02-10-2015, 08:30 PM   #10
kg6mov
Hears the voices
kg6mov's Avatar
Yes, stock is 18" front and back.
Depending on options, how much fuel in the tank, crap in the back, or my mother in law on the hood those number can vary by an inch or so.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread 02-10-2015, 11:25 PM   #11
Taz360ZJ
i should've said.......... buy me some 7" IRO coils, and I'd give you my 5.5" IRO coils
Slate 5.9 Limited: 8", 231, 8.8, 5 SPD & blower awaiting
Stone white 5.9 Limited: 30's, 231, ECE's
Taz360ZJ is offline   Reply With Quote Quick reply to this message
Unread 02-11-2015, 12:41 AM   #12
Kolak
Vendor
Kolak's Avatar
I'm an IRO dealer so if anyone needs anything, please PM me
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is online now   Reply With Quote Quick reply to this message
Unread 02-11-2015, 08:29 AM   #13
Dubfire98
Kolak i just ordered a rear TB from you yesterday... lol ah just take all my money!!! hahaha
TN JEEPER
Unread 02-12-2015, 01:03 AM   #14
Kolak
Vendor
Kolak's Avatar
Well I really appreciate your spending your money with me
Unread 02-13-2015, 09:56 AM   #15
Dubfire98
Money well spent. Quality stuff as always
TN JEEPER
