60,000 mile service? - JeepForum.com
post #1 of 33 Old 12-15-2005, 06:55 AM Thread Starter
ashy22
2005 WK
Hi Guys
I am about to do a 60,000 mile service on my 1999 4.7 GC Ltd.
Do you guys think that replacing the spark plug wires is a bit over the top as this is listed in the maintanance schedule?
When replacing the front & rear diff fluids, is a new gasket required for the covers?
Any tips?
Cheers
Paul
2005 GC 5.7 Hemi(WH-Export)QDII
1971 Corvette 454
1969 Plymouth RR 383
ashy22 is offline
post #2 of 33 Old 12-15-2005, 07:09 AM
ksgrands
I don't replace items like that, these are guidelines to help keep your ride in tip-top shape, get the best gas-mileage, etc. I'm not loaded, so I use my own judjment on these things.
Silicone is an acceptable gasket for diffs. Although I prefer gaskets. The old ones are not re-usable if thats what your're asking.
97ZJ
00WJ-Sold
90 Comanche Pioneer 4x4, 3inches, 31's SOLD
89 Comanche Pioneer 2wd
97 Wrangler Sport
ksgrands is offline
post #3 of 33 Old 12-15-2005, 07:11 AM
mr_user
Originally Posted by ashy22
Hi Guys
Any tips?
Cheers
Paul
Plugs and all that good stuff is an easy saturday job in your own garage. Get an igntion tune up kit at the auto store with a wobble socket and wobble extensions as well as a socket with the rubber inside for the spark plugs.
Diff fluids are very easy as well, stealer wants around 300 i think unless covered by warranty. Do it yourself, and yes coat the housing cover with some RTV, you do not need a special gasket.
Matt
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #4 of 33 Old 12-15-2005, 07:24 AM
rrubio
rrubio's Avatar
I recommend if you havent switch to synthetics.Iv'e always used RTV called the Right stuff a bit pricey but works great and you don't have to wait till it dries to put the cover back on.
rrubio is offline
post #5 of 33 Old 12-15-2005, 07:58 AM
mr_fsu_guy
2006 XK Commander
Pardon me asking but where could I get some soild step by step instructions on how to do this myself, and what to look for and what to unscrew and put in, and put back together. Basically someone hold my hand I've never done anything like this.
2006 Trail Rated Limited Commander ~ 5.7L Hemi ~ 62k miles
mr_fsu_guy is offline
post #6 of 33 Old 12-15-2005, 08:01 AM
rrubio
rrubio's Avatar
Your joking correct.
rrubio is offline
post #7 of 33 Old 12-15-2005, 08:16 AM
mr_fsu_guy
2006 XK Commander
I said I've never changed that - I don't know what to do... if its as easy as unbolting the case, out with the old in with the new, and rebolt - thats all you had to say.
post #8 of 33 Old 12-15-2005, 08:21 AM
rrubio
rrubio's Avatar
Just giving you a hard time that it is all.But I honestly thought you were joking.Very easy procedure.Unloosen the bolts and let it drain then take the bolts completly off and scrape off the residue from the previous gasket.Get a few cans of brake cleaner and spray the heck out of the carrier.Clean off the diff cover and make sure the magnet is clean and put back together using RTV, personally use The Right Stuff gasket sealer.Since your there go to Synthetics a bit more but worth it in my opinion.
rrubio is offline
post #9 of 33 Old 12-15-2005, 09:02 AM Thread Starter
ashy22
2005 WK
When you say synthetics... I take it you mean an alternative to the fluid that the main dealer will give to me when I pick up the fluids & parts required.
Can you suggest a better alternative than the stock fluid?
1971 Corvette 454
ashy22 is offline
post #10 of 33 Old 12-15-2005, 09:29 AM
mr_fsu_guy
2006 XK Commander
When he means synthethic he means this
I know check the manual - I just ran out to get it... only this just confused me...
It tells me to use 80w90, and if I trailer to use 75w140 in the rear and with Qdrive use 75w140 & a friction modifier additive. What is best - i thought 80w90 is for like buses and stuff. What do I use for a regular DD - no towing?
I've only ever used mobil1 products and they only make 3 weights 75w-140, and 75w-90, and a 80w-90 which is for heavy duty applications. I assume the 75w-140 is what most people would use in front and rear?
post #11 of 33 Old 12-15-2005, 09:40 AM
Myrtle Beach
Just so you know--- The 4.7 doesn't have spark plug wires. It uses a coil over the plug system. It is a pretty easy job to change all the plugs, it just takes some time. Try www.wjjeeps.com for some help. the only other thing you need to do is start driving your jeep more. Only 60K on a '99 is nothing
---99 Jeep Grand Cheerokee Limited 4.7 V8 -2" Lift -265X75 BFG---
Myrtle Beach is offline
post #12 of 33 Old 12-15-2005, 09:41 AM
rrubio
rrubio's Avatar
I personally use Amsoil.
rrubio is offline
post #13 of 33 Old 12-15-2005, 06:01 PM
gkbid
I was also planning to upgrade to a synthetic on my GC, it has the Vari-Lok differentials, do I still need to add a fricton modifier with a synthetic? If yes, is there an option to the dealer brand at $18/bottle?
Thanks..
Gary
2004 WJ Limited Overland
4.7L HO, Black, 4X4 QuadraDrive w/Vari-Loks
Past Jeeps: 2001 WJ 4.7 Ltd / 1999 WJ 4.7 Ltd / 1993 ZJ 5.2 GW, 1988 XJ 4.0 Ltd
gkbid is offline
post #14 of 33 Old 12-15-2005, 06:06 PM
rrubio
rrubio's Avatar
Thanks..
Gary
Im not sure but im pretty sure some synthetics you can get that bottle also.I don 't have vari-loc so the normal synthetic Amsoil worked for me.
rrubio is offline
post #15 of 33 Old 12-15-2005, 06:46 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Thanks..
Gary
$18 per bottle?!? Are you kidding??
Last bottle I bought from the dealer was $6 and some change.
Wheelin98TJ is online now
46k km or 30k mile service afss WK Grand Cherokee & XK Commander Forum 4 12-07-2009 03:43 PM
What should I do in the 60,000 mile service? tivoboy ZJ Grand Cherokee Forum 13 07-21-2009 08:13 PM
30K Mile Service Question (Dealer to do service) Natemare13 WK Grand Cherokee & XK Commander Forum 3 03-24-2009 11:52 AM
30k mile service? onrails ZJ Grand Cherokee Forum 3 02-12-2006 08:20 PM
30k mile service for 4.0L I6 JCDubya ZJ Grand Cherokee Forum 9 10-16-2005 11:18 AM
