6 Cyl engine coolant drain plug . . . ? - JeepForum.com
post #1 of 3 Old 02-18-2002, 03:29 PM Thread Starter
Humberto Benavides
Humberto Benavides's Avatar
Does any body know where exactly is the engine coolant drain plug..? Is easy to reach it......? I need to replace the coolant on my '95 Grand Cherokee (6 Cyl-2wd) and I think that the 60% more or less of the coolant is in the engine, so I need to flush the engine too.....!
Thanks to all !
'03 Jeep Wrangler X Auto I6 4.0L, 3.5" RE Super Flex, 1" PA BL, M.O.R.E. 1" MML, 33x12.5x15 MT/R's, JKS Quick Discos, RE Front Adjustable Trackbar, Skyjacker Hydro7000 Shocks, OEM RUBICON Rocker Guards, WARN Steering Skidplate, Front Mopar Tow Hooks, Bushwacker 6" Extended Fender Flares, K&N drop-in air filter, Chicago Electric Winch, SS light bar with 4 Hella 500 Driving Lights, and stock no more !
OOOO
[ŻŻŻŻ]
o||||o
▒-o-▒
Humberto Benavides is offline
post #2 of 3 Old 02-24-2002, 07:30 PM
kuzma97ZJ
should be on the driver side up from where the the oil pan meets the block. You'll need a allen wrench to get it out. If that fails buy a Haynes garage manual it will tell you how to do this and more, they cost like $15.00.
1997 grand cherokee 4.0L, forest green, 3" skyjacker, 1" spacers, adj. front track bar, skyjacker sway bar dissconnects, procomp steering stabilizer, 31" super swamper LTB's, safari bar w/ 2 KC's, custom roof rack w/ 2 KC's, tow hooks front and back, CB, dynomax turbo muffler, custom K&N filter charger, 2 12" sony explode subs.
kuzma97ZJ is offline
post #3 of 3 Old 02-24-2002, 10:55 PM
Kess
its kinda hard to see, but if ur lookin at the engine under the hood look all teh way to teh left of the radiator and straight down, its donw there kinda hidden
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
Engine Block Drain Plug 4.7L V8, Where is it? lvdent ZJ Grand Cherokee Forum 1 08-09-2009 10:29 AM
need wrench for engine block coolant drain plug cwolf41 ZJ Grand Cherokee Forum 2 07-09-2009 06:30 PM
Engine drain plug ///BHRpowered ZJ Grand Cherokee Forum 20 05-30-2006 01:31 PM
Coolant Engine Drain PLug -Joe- ZJ Grand Cherokee Forum 3 02-20-2005 03:56 PM
