6 Codes... New to codes and Tranny issues - JeepForum.com
post #1 of 7 Old 02-05-2008, 04:07 PM Thread Starter
jakewalczak
I checked for codes and just to throw this out there. I have tried many times to check for these and I don't know if I am an idiot or not, but never got it to work.
What I didn't realize is that you have to quickly switch from on to off, I had always gone slow. I don't know if that is implied; but if any of you have trouble with it... go blitz on it.
alright: I got 12-45-37-45 (again?)- 21-55.
I did it twice and got the same numbers in the same order.
Can I get their meaning please and why there are so many and why I had 45 twice? Please.
I know my coolant sensor is bad and that I have Rear light failure (according to VIC) I also know that my tranny has really been acting up and not wanting to shift into 1st when I have proper levels of fluid (brown I know) and I am sure it is in drive. I also know that I had my computer updated a year ago and that they changed something with the O2 sensor and now it is not "reading the right levels" or something; I didn't pay much attention because stealer ship said it wasn't a big deal and told me they'd charge 200$.
I know jack about codes and about transmissions or 02 sensors... but if I can get good enough direction/instructions I feel I can do quite a bit on my own.
I am also wondering if I should just bite the bullet and take the car in due to tranny troubles (http://www.jeepforum.com/forum/f13/96-zj-can-t-shift-out-1st-gear-512391/)
I am just worried that I will do further harm and cause more damage by ignoring it.
I don't mean to impose, but I would love some feedback, info, any links to other posts (i suck at using the search feature), or even just the advice to take it in somewhere.
I have a FSM on my computer so I can always check that, just don't know where to begin or really what to do.
THANKS!!!!!!!!!!!
1996 4.0L Jeep Grand Cherokee Laredo. Original and Stock everything. 177K miles.
jakewalczak is offline
post #2 of 7 Old 02-05-2008, 04:19 PM
KingPrat
Alright, 12 and 55 are basically always there. 12 says that the battery has been disconnected in the last 50 starts. 55 is end of codes.
37: torque converter solenoid circuit fault
45: Overdrive solenoid. Problem detected in the overdrive solenoid circuit
Is your transmission in limp mode? (won't shift out of 2nd or so) Nevermind....saw your other thread.
Sounds like you have electrical problems. Could just be the sensors. hopefully someone can chime in a little more.
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #3 of 7 Old 02-05-2008, 09:38 PM Thread Starter
jakewalczak
Thanks for that info... im sure there is a list of those codes; where could I find them?
For code 37 & 45; what should I do with that- replace or something? I honestly don't know where or what they are or do... And why might 45 come up twice?
Thanks
post #4 of 7 Old 02-05-2008, 10:51 PM
KingPrat
Here's the link. http://hem.passagen.se/suntool/jeep/error_en.html
I know it says 93-95, but they're pretty standard through 98.
And the code popped up twice cuz there were 2 seperate times that the code was thrown.
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #5 of 7 Old 02-06-2008, 02:10 PM Thread Starter
jakewalczak
Thanks for that man, appreciated.
Now what do I do to correct these codes? Do I take it in or try to mess around with it on my own?
Does anyone have any assistance for this?
Thanksssssssssssss
post #6 of 7 Old 02-06-2008, 05:55 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Remove the positive battery cable for a few minutes. Turn the ignition to Start once with the cable removed. This will clear the codes. Then after a drive or two, pull the codes again and see what returns.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #7 of 7 Old 02-06-2008, 08:32 PM Thread Starter
jakewalczak
alright.
Once the blizzard dies down a bit ill do that and post results probably after the weekend.
Thanks for your direction.
Fault Codes, DTC Diagnostic Trouble codes ETC. ef1992 ZJ Grand Cherokee Forum 4 07-16-2009 02:59 PM
2K WJ not running right with fuel inj codes & No ASD relay output voltage codes. HELP hillside250 ZJ Grand Cherokee Forum 0 04-06-2009 03:17 AM
TCM P0750...codes and more codes and the one speed tranny Mattt0305 WK Grand Cherokee & XK Commander Forum 3 11-01-2008 10:50 PM
Tranny codes SX400 ZJ Grand Cherokee Forum 5 01-23-2007 07:02 PM
Tranny error codes CJjacquez ZJ Grand Cherokee Forum 3 10-20-2006 04:51 PM
