545RFE-Is it any good? - JeepForum.com
post #1 of 7 Old 10-25-2005, 03:50 PM Thread Starter
Dieseljoe
2006 WK
I'll be buying a 06 Grand Cherekee Overland in May and I'm trying to get as much info on Jeeps.This will be my first one.I've lost faith in Ford so I'll jump ship(I hope it's worth it)and buy a Jeep.My question is about the 5 speed auto transmission 545RFE.Is it any good?I've heard there might be some problems with this tranny.Any info would be great.Joe
Dieseljoe is offline
post #2 of 7 Old 10-25-2005, 03:55 PM
HemiWay
That tranny is fine but the different one that is mated with the V6 had problems in 05. That transmission with my Hemi has performed flawlessly.
05 WK Hemi Midnight Blue
Former Jeeps 93 Ltd V8, 96 Ltd V8
Other Vehicle - Wife's Envoy XUV
HemiWay is offline
post #3 of 7 Old 10-25-2005, 04:15 PM
brandoncrone
Its an awesome tranny, Ive been rebuilding transmissions for years and the 7 years that it has been around, Ive never had to rebuild one.
Dodge/Chrysler/Jeep Technician 14 Years
ASE Master Certified
L1 Advanced Engine Performance
brandoncrone is offline
post #4 of 7 Old 10-25-2005, 04:59 PM
soldierguy
soldierguy's Avatar
I agree with what's been posted. I've got the 545RFE in my 05 WK hemi, and the 45RFE (the early version of the 545RFE with one less gear) in my 00 Dakota. Both are smooth and responsive and I haven't had a single problem with either one. They do have a tendency to get into the highest gear possible as soon as possible in normal driving...they'll jump out of 5th or 4th pretty easily with a reasonable prod of the gas pedal, but it really doesn't like to move from 3rd to 2nd unless you're really into the gas pedal. They don't hunt for gears much either...generally the programming for gear changes is good. I could go on and on about how it goes about its business, but the bottom line is that it's a good transmission from both a reliability and drivability perspective.
Hemiway is right...there have been some issues with the W5A580 transmission mated to the V6...that's the re-worked benz transmission that is also used in the 300C/Magnum/Charger when equipped with the hemi engine. The problems with that have centered around water in the fluid causing shuddering, and fluid leaking out if it gets too hot causing a fire risk. Those issues don't seem to be present in the 300C/Magnum/Charger that I'm aware of, so it's just something with the installation of it in the WK.
soldierguy
2012 Wrangler Rubicon 2-door
2009 Aprilia Dorsoduro 750
2008 MV Agusta Brutale 910S
soldierguy is offline
post #5 of 7 Old 10-25-2005, 07:30 PM
brandoncrone
Also wanted to mention that the 45RFE is the exact same transmission. Soldierguy, you could have the 545 in your Dakota simply by getting a trans controller from a truck with the 545 in it. Ive been told that you can reprogram the existing controller to give the vehicle the 5th gear. Also the 545 will soon have a flash to make it a 645. The trans is basically able to produce 6 forward and two reverse gears (different models will utilize one of the two reverse gear ratios).
Also I wanted to mention that the Hemi in the LX cars (300C, Magnum and Charger) use the 545RFE trans. The 3.5L uses the NAG (MB trans). This trans does not have the torque capacity to handle the Hemi....looks like we have one step up on the Germans!
post #6 of 7 Old 10-25-2005, 07:38 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I'll chime in too... good tranny... way better than the tranny's they have put in any 6 cyl grands...
2013 FR-S
BlaineWasHere is offline
post #7 of 7 Old 10-25-2005, 07:40 PM
BlaineWasHere
BecauseRacecar
On the WJ you can go to the dealer and make the 99-00's a 5 speed like the 01-04's but either the dealers don't know what you are talking about or want to much money... I wonder if it would help with highway gas miliage...
2013 FR-S
Possible WJ 545RFE Issue? WiCkeDuDe ZJ Grand Cherokee Forum 3 10-26-2009 08:08 PM
545RFE gasket? chrisstromberg ZJ Grand Cherokee Forum 4 03-23-2009 11:42 AM
45RFE vs. 545RFE the88thpianoman ZJ Grand Cherokee Forum 3 06-06-2008 06:50 PM
545RFE-Any changes? Dieseljoe WK Grand Cherokee & XK Commander Forum 4 04-11-2008 08:45 AM
545RFE flash. OneGravenKiss ZJ Grand Cherokee Forum 23 05-29-2006 03:09 PM
