Is 500 rpm too low for idle? - Page 2 - JeepForum.com
post #16 of 36 Old 01-25-2013, 09:39 AM
FAlfani81
Originally Posted by PolkaPower View Post
700-800 is normal.
Really? is it different for a 4.0 then the 5.2? I thought they idled about the same.
FAlfani81 is offline
post #17 of 36 Old 01-25-2013, 09:49 AM
PolkaPower
I think so too. Maybe 600-800 range for idle to give it more room but 700 being the sweet spot! 500 is on the low side.
PolkaPower is online now
post #18 of 36 Old 01-25-2013, 09:53 AM
rcMikeS1990
1994 ZJ
700-800 is normal. Possible bad IAC sensor.
For the 5.2 or 4.0?
1994 Grand Cherokee Limited 5.2L V8 318, Spectre cold air intake, Flowmaster Super44 muffler to 3.5" resonator tip, 30x9.5 BFG A/T's, Custom Tranny and TC shifter mod
My Build Thread--not sure how to make that the link-http://www.jeepforum.com/forum/f13/my-build-thread-1568707/
rcMikeS1990 is offline
post #19 of 36 Old 01-25-2013, 10:01 AM
MTBlue
That's pretty much what I gleaned from this whole thread too. Try cleaning your IAC with brake cleaner (no carb cleaner. Too hard on sensors), and if it is still idling low, replace the sensor. Also, check your MAP sensor connection and any codes your Jeep might be throwing. My 4.0 idled rough to the point where my CEL came on. Threw the "bad MAP sensor" codes, so I replaced it. Purred like a kitten after the combo of clean IAC and new MAP. Never had to deal with engine mounts, so hopefully others will chime in on that portion.
Hope that helped,
-Evan
Dirt Deprived
MTBlue is offline
post #20 of 36 Old 01-25-2013, 10:02 AM
PolkaPower
Originally Posted by rcMikeS1990 View Post
For the 5.2 or 4.0?
I am guessing for both. If you clean the IAC do not move the plunger in and out. If you buy a new one get a Mopar OEM replacement.
post #21 of 36 Old 01-25-2013, 10:38 AM
bananaslug
How are your motor mounts? Any changes to the engine?
When I got the 703 injectors they lowered my idle.
bananaslug is offline
post #22 of 36 Old 01-25-2013, 10:47 AM
B93
I've had two 5.9s, both idle at 700 (one at like 730).
1998 Grand Cherokee 5.9 Limited. ~356,000 kms
B93 is offline
post #23 of 36 Old 01-25-2013, 11:06 AM
rcMikeS1990
1994 ZJ
I have cleaned it properly, the reason mine appears to be so low is bc i forgot those pics were taken while I was stopped in drive, not true idle
That's probably closer to how yours is I bet. Thats idle in park, others were idle in drive so there was a load
post #24 of 36 Old 01-25-2013, 11:09 AM
PolkaPower
Attachment 550568
Yes.
post #25 of 36 Old 01-25-2013, 07:33 PM
papitt
SO What does the MAP sensor look like and where is it.
papitt is offline
post #26 of 36 Old 01-25-2013, 07:38 PM
ZeeJay1997
It's a square plastic box that is mounted to the drivers side of the throttle body.
ZeeJay1997 is offline
post #27 of 36 Old 01-25-2013, 08:42 PM
jnowak
Removed
jnowak is offline
post #28 of 36 Old 01-26-2013, 08:27 AM Thread Starter
kb9mfd
Can the MAP sensor be bad without throwing any error codes? Only the idle seems a little low, and after cleaning the IAC, the idle does not change when put under load (like the A/C pump or putting it in drive), but it use to. I cleaned the IAC its self but I did not know how to get into the hole it sits in to clean that. Could I take the body it sits in off the intake and clean that? Since its a '95 with 135k the chances are neither of them have ever been replaced. The previous owner is a friend of mime and I have all the service documents and they where never serviced, and he had it for 10+ years. - Jeremy
kb9mfd is offline
post #29 of 36 Old 01-26-2013, 08:42 AM
ZeeJay1997
Yes. Get some carb cleaner and a new gasket. Take all the sensors off and soak and clean the throttle body.. You can use soft brush or Q-tip to clean IAC ports, just dont scrape the seat for the plunger. The TPS screws can be tough to get out, but i found that if you back them out until they get stiff, then spray penetrate, then run them back in. Keep repeating this until they are out. Also check the small port for the MAP tube for clog and be careful with the elbow.
post #30 of 36 Old 01-26-2013, 09:41 PM
MTBlue
Awesome advice. Had to use most of that when I redid my IAC and MAP sensors. The screws on my TPS WOULD NOT come out, and since I had to replace the whole thong anyway, I just broke the damn thing off completely.
Dirt Deprived
MTBlue is offline
engine , idle speed
