5.9L stroked or no? - Page 2 - JeepForum.com
post #16 of 29 Old 09-14-2009, 04:49 PM
the88thpianoman
2003 WJ
If you have the time, (parent's?) money, and initiative, then go for it. However, IMO this will probably end up being more of a hassle and headache than fun project by the time you're through with making everything work.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #17 of 29 Old 09-14-2009, 06:22 PM
squashman702
1994 ZJ
Originally Posted by ratmonkey View Post
here's my list so far.
complete junkyard 5.9, rusty but decent internally 500$
bore and hone, media blast, hot tank, new cam bearings, new freeze plugs, new tower bushing. 650$
esp 4" crank(cast), forged rods, custom 10.5:1 srp pistons. 1200$
assembly, file fit rings, two sets of main bearings since the crank journals were between sizes. 740
up on deck, hughes cam and valve springs 300$
gasket kit and timing set, 200$
heads(already on my other motor) 750$
air gap intake from hughes(on my other motor) 750
sct tuner 550
manual transmission and performance clutch swap, 1350 in total parts
8.8 rear swap, rebuid and brackets(not counting claytons arms and frame side) 900$
front wj akebono and rear cobra brakes 500$
i'm sure there'll be a hp30 or tj d44 in the front end next as well.
Show me F&R brakes for $500 and I'll buy sets for both of my ZJ's. WJ swap is $550 for the front alone easy.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #18 of 29 Old 09-14-2009, 06:59 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
lol, junkyard man, 25$ per knuckle, 30$ per front caliper and bracket. 75$ for each mustang cobra caliper, bracket, and backing plate(for the 8.8 obviously).
rest is rotors, pads, spacers, and tie rod.
ratmonkey is offline
post #19 of 29 Old 09-14-2009, 07:08 PM
UrbanOffRoad124
Do you have another vehicle??? If you have another vehicle and you have the money, do it! The 'know how' is all relative, either you have it or you'll learn it. There's a first time for everything, pop your's and that jeep's cherry at the same time!
If you don't, get a second vehicle and then tackle this project. I'm lookin at buying another DD just so I can do bigger projects to my WJ. I want to do a 242 swap cause my 247 is giving me ****, but these things are hard to pull off without another vehicle to get to the parts store, work, or in your case, school.
My brother has been piecing together a 4.0 stroker for his XJ for a year now, he has two D44, and a list of parts still growing.
'02 WJ | 4.7HO | Limited | QDII | 3.5" Lift (BB+OME Springs) | JKS TB | JKS Quick Disco's | JKS BPE's | RC Nitro 9000's | Rusty's SS | K&N FIPK | 40 Series Delta | Cat-Delete |
Coming soon: 31" KM2's | 15x8 Cragar V-5's
#236 |
#232
"those who do, can't explain; those who don't, can't understand"
UrbanOffRoad124 is offline
post #20 of 29 Old 09-14-2009, 09:30 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
if you can afford to do it.... i say do it... i had to put a new motor in my 5.9, i went with a stock engine.... now i wish i saved up and did at least a stroker..... i do realy regreat that, o well.... mabe after my first deployment.
you only live once, enjoy it.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #21 of 29 Old 09-14-2009, 09:36 PM
spife7980
im going to second that. if you have another vehicle and dont depend on this one i say by all means try it.
but if you dont i would steer as far away from it as possible because this is the type of project i see the jeep being sidelined for weeks at a time on. im seeing murphy coming in and kicking the **** out of anything and everything possible.
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #22 of 29 Old 09-14-2009, 09:50 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
If you are going to go to all the trouble, do the Hughes 426 stoker kit. 426 small block to match your built tranny. And spend the prime of your life tuning it.
HighLonesome is offline
post #23 of 29 Old 09-14-2009, 09:51 PM
JrMechanic
I think this is all the motivation you need:
YouTube - Supercharged 6.7L ZJ Burnout
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #24 of 29 Old 09-14-2009, 11:06 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The 426 seems to be pretty failure prone compared to the 408.
post #25 of 29 Old 09-15-2009, 08:12 AM Thread Starter
Travis873o
well trust me i do realize this aint gonna be cheap. luckily thanks to financial aide and how i filed the fafsa for school, everyone here is probably paying for my school. lol
but set aside the point of whether or not this is time/financially smart, what would be the pros/cons of the stroker kit? and i'd prob go w/ a 408 instead of 426.
Travis873o is offline
post #26 of 29 Old 09-15-2009, 08:43 AM
the88thpianoman
2003 WJ
You want to misappropriate your financial aid money to doing a stroked engine swap?? I am out of this thread
post #27 of 29 Old 09-15-2009, 09:03 AM
HighLonesome
This is one pipedream of a thread.
post #28 of 29 Old 09-15-2009, 10:58 AM Thread Starter
Travis873o
I started this thread asking what were the mechanical pros and cons about stroking/boring it. Not whether it is financially smart. Now if anyone has any input on whether or not the life of the engine would be hindered or what advantages I'd gain. Etc., please tell. However, I do not need input on what I should with Excess financial aid. Thanks.
post #29 of 29 Old 09-15-2009, 12:19 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Jeep 360 Grand Cherokee Crate Engine with 325 horsepower and 370 ft-lbs of torque.
$2,399.95
Jeep Performance Crate Engines
BTW,
if you started the thread on the engine, stay on topic. You started the financial aid discussion.
Your Friendly Moderator.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
Anyone with a stroked 4.0? mdsuave13 ZJ Grand Cherokee Forum 16 01-31-2008 07:14 PM
