5.9l ac discharge hose? - JeepForum.com
post #1 of 5 Old 05-22-2014, 01:22 PM Thread Starter
mreibsamen
hello all,
Ne member here. My AC discharge hose broke on my 5.9l. Can't seem to find a replacement with the 2nd sensor. Any ideas? Could I use the single sensor one somehow?
thanks!
mreibsamen is offline
post #2 of 5 Old 05-22-2014, 06:51 PM
Brendan4862
2003 WJ
I had this problem as well, I found a donor 5.9 and took the line. The second plug (that is only on 5.9) is for the e-fan. It tells the fan to turn on when ac is on.
There is no substitute for a Jeep
Brendan4862 is offline
post #3 of 5 Old 05-22-2014, 07:20 PM
firsttimeZJ13
If that's the case, could be bypass the second one with a switch?
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline
post #4 of 5 Old 05-22-2014, 07:46 PM
zjosh93
Most places have an hose shop reasonably close that can fix your old hose. Usually the only problem is the hose is old and hard. It's a cheap fix for new hose and crimped ends. They can even braise another sensor port to the single port hose if you want. Might want to call and see what they think is your best option.
zjosh93 is offline
post #5 of 5 Old 05-23-2014, 06:10 AM
PolkaPower
That part isn't made anymore. Either find one from a junked 5.9 or have the broken one repaired. You need both switches. One is for the e fan.
PolkaPower is offline
