5.9 vibration damper install? need advice!!! - JeepForum.com
post #1 of 10 Old 08-24-2013, 07:56 PM Thread Starter
SpenceAK
is the back of the damper supposed to be flush with the seal? i used a presser tool and it started getting really tight but didn't seem like it was going on anymore. help please!
SpenceAK is offline
post #2 of 10 Old 08-25-2013, 02:51 PM
PolkaPower
Are you talking about the harmonic balancer?
PolkaPower is offline
post #3 of 10 Old 08-25-2013, 02:52 PM Thread Starter
SpenceAK
Yes
SpenceAK is offline
post #4 of 10 Old 08-25-2013, 02:56 PM
PolkaPower
It only goes on so far. Double check that it's lined up with the rest of the pulleys.
post #5 of 10 Old 08-25-2013, 03:07 PM
Oldfrog
2007 WK
Dont know about the 5.9, but I just replaced mine on the 4.0 last week. There is a tiny bit of damper sticking out over the end of the crankshaft, at the bolt location, when it's done. I wanted mine flush, too....but it wasnt going to happen. I bought my damper from the dealer, so it's the correct one.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #6 of 10 Old 08-25-2013, 03:08 PM Thread Starter
SpenceAK
Yup I did the crank pulley is aligned with the water pump pulley. I was informed on the dodge forum that the 5.9 balancer doesn't go flush with seal. I just rebuilt my 5.9 so it's sitting on the engine stand only have the water pump on. thanks polka
SpenceAK is offline
post #7 of 10 Old 08-25-2013, 03:12 PM Thread Starter
SpenceAK
My damper is the original one
SpenceAK is offline
post #8 of 10 Old 08-25-2013, 03:21 PM
PolkaPower
I would just replace it with a new one since you have access to it. The new one is updated.
post #9 of 10 Old 08-25-2013, 03:31 PM
Oldfrog
2007 WK
Ditto.
Mine started coming apart when the ZJ was loaded down for a coastal fishing trip, while in the drive thru window at the bank. I was thankful it didnt happen on the Interstate between nowhere and somewhere. Luckily, the dealer had ONE in stock. ( and no...it wasnt cheap) Needless to say, my trip was delayed a 1/2 day.
Oldfrog is offline
post #10 of 10 Old 08-25-2013, 03:32 PM
PolkaPower
I got mine from Kolak. I believe it was less than 100 bucks.
