5.9 swap, will this work? - JeepForum.com
post #1 of 28 Old 07-09-2009, 10:05 AM Thread Starter
rustynail
Hello everyone! I found out the hard way that my jeep is not a submarine and now my 5.2 has a knock that is worsening.
I found a guy parting out a 2002 RAM 1500 and he has the 5.9 engine with wiring harness and ECU, trans, transfer case and some other parts.
Will this motor work? Do I need the 46RE? Will his ECU work, do I even need a different one? Will the TC work? Any info is appreciated as I know very little about this swap.
Any helpful links are appreciated. Thanks
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline
post #2 of 28 Old 07-09-2009, 10:23 AM
newfieZJ
all you need is the engine , your intake and sensors , and your PCM will work fine until you get it flashed for performance if needed . the PCM , trans , and t-case are of no use to you at all from the 02
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 28 Old 07-09-2009, 10:35 AM Thread Starter
rustynail
The seller is including the wiring harness and ECU with the engine, are they useless to me? What else do I need for the swap? Would it be easier to just rebuild my 5.2
- Russ
post #4 of 28 Old 07-09-2009, 10:41 AM
RyanZJ
RyanZJ's Avatar
You could always get everything from the seller and then sell what you don't need. Maybe recoup some of your costs...
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #5 of 28 Old 07-09-2009, 10:52 AM Thread Starter
rustynail
Here's the ad, he is asking $1000CAN obo for everything. How should I proceed?
Pulled from a 2002 Dodge Ram 1500 with 140k on it. This is all I have, if it is not listed for sale, I dont have it for sale.
Engine is a 5.9 GAS V8 (NOT the diesel) $600 YOu get the harness as well as the ECU
Automatic transmission $600
Transfercase $100
Rear diff 3.9 ratio, missing calipers, $50
Also have:
-Radiator ($50)
-A/C condensor/fan assy ($50)
-Infiniti CD player ($50) and amp ($50)
-RF headlight ($50)
-Left rear Tail light, used, ok shape ($30)
-3rd brake light assy ($20)
-steering column/wheel (steering wheel not torn or worn out but is getting beat up just sitting there) $20
Make me an offer. I would be really happy to not have to separate the engine/tranny.
- Russ
post #6 of 28 Old 07-09-2009, 10:52 AM
newfieZJ
the ECU controls the trans , yours a 44RE , his a 46RE . the trans is no good to you , the starter is on the opposite side for starters . The length would require new driveshafts etc etc . The two engines are both OBDII but , to keep things in check with your PCM , run the 96 stuff . Some sensors will be the same , check part numbers for references . The T-case , AFIK , has a different speed sensor and another obstical I'll have to get back to you on , I asked about this before . I had a 5.2/46RE/HD242 sitting in my garage from a 2001
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #7 of 28 Old 07-09-2009, 10:54 AM
RyanZJ
RyanZJ's Avatar
Just get the motor, then sell the ECU and harness and use your current one.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #8 of 28 Old 07-09-2009, 10:57 AM Thread Starter
rustynail
What should I pay for the motor?
- Russ
post #9 of 28 Old 07-09-2009, 11:04 AM
newfieZJ
It's a nice find for sure , if you get it for $500 , even the $600 considering he's got to separate them , that's not bad for a low K 5.9 IMO
Myself , I would go for just the engine , no harness or ECU/PCM and offer 5 bills , go from there
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #10 of 28 Old 07-09-2009, 11:12 AM Thread Starter
rustynail
Sounds like a good plan to me. I'm terrified of buying the motor and then finding out that I need a ton of other crap. Any thoughts on this? I thought I read somewhere that I needed more parts. Is my starter going to work? Am I understanding that the trans will not work? My trans is fine but who knows for how long after the 5.9 goes in.
- Russ
post #11 of 28 Old 07-09-2009, 11:40 AM
RyanZJ
RyanZJ's Avatar
You'll need to get a new flexplate at least. Your current starter should work. Your current trans will work as well.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #12 of 28 Old 07-09-2009, 11:56 AM Thread Starter
rustynail
Will the flex plate from the '02 Ram work or do I need to order one? If I need to order it do I order it for a '98 5.9 Grand?
- Russ
post #13 of 28 Old 07-09-2009, 12:20 PM
RyanZJ
RyanZJ's Avatar
I don't believe the flexplate from the (Dodge) 5.9 will work. Maybe five.nein will chime in with some additional information. He's done a few of these swaps and is a great resource.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #14 of 28 Old 07-09-2009, 12:52 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Guessing the flexplate will work. Unless all Magnum V8s don't use the same crank flange, but I think they do. And pretty sure the torque converter bolt holes will line up.
HighLonesome is offline
post #15 of 28 Old 07-09-2009, 01:15 PM Thread Starter
rustynail
five.nein how do you feel about the '02 46RE that is attached to the motor? I know I don't NEED it but will it work? Is it not the same tranny that is in a '98 5.9 Grand? I might be able to get it for a reasonable price since the guy would like to not have to separate the two.
- Russ
249 To 231 Swap, Will this one work? DothanJeep ZJ Grand Cherokee Forum 16 09-17-2009 10:48 PM
will a 2001 wj tc work for my 242 swap in my zj? vansskaterfreek ZJ Grand Cherokee Forum 1 01-24-2009 05:22 PM
Which axle swap is best....or will work? jeepnurse ZJ Grand Cherokee Forum 6 06-25-2008 11:26 AM
ZJ NP231 swap, how to make VIC "work"??? BradMB2004 ZJ Grand Cherokee Forum 6 01-14-2007 09:49 AM
95 ZJ Power Window issues... work.. don't work... slgunnel ZJ Grand Cherokee Forum 7 11-30-2006 04:05 PM
