5.9 swap Questions - Page 2 - JeepForum.com
post #16 of 27 Old 08-14-2013, 08:19 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by David97 View Post
If anyone has any tips/tricks they want to share feel free as well.
Basically do things that are easy with the motor out that are relative PITAs when the motor is in.
Replace the front trans seal.
Get both EGR gaskets ahead of time.
Do the plenum gasket fix.
Be careful not to bend the CPS bracket when you mate the motor to the trans.
Depending on how many miles on the new motor:
Replace rear main seal, oil pump and pickup. And oil pan gasket of course.
Replace front engine seal (Viton is best) and use the Mopar performance gasket on the timing cover. You will need to buy that gasket separately. If you have ever had to replace a timing cover gasket, you'll understand why to use the best. Low center of page
http://www.mopartsracing.com/parts/ram.html
Check the plugs and do a compression check. If anything is iffy, time to pull the heads. That's easy work with the motor on a stand.
This is the best gasket set I have used
http://www.summitracing.com/parts/sl...iew/make/dodge
All I can think of now.
HighLonesome is online now
post #17 of 27 Old 08-14-2013, 09:16 AM Thread Starter
David97
Yeah, I plan on completely rebuilding the 360 before it goes in regardless lol. Gonna tear it down, and send it off to get machined and all that good stuff. Mostly, because I want no more leaks. But I also want my motor to last for a very long time.
Now the wait to get everything, and to get her done. Though I'm not gonna rush this, I think I can get everything needed by the end of the month. Then spend all of September having it sent it for honing, porting and polishing, and whatever other machining it may need. Plus rebuilding it, I should have a pretty damn reliable motor in my 95 by end of September. Still sucks waiting though
Thanks again man.
David97 is offline
post #18 of 27 Old 08-14-2013, 09:28 AM
zj97ltd
This is the same route I'll eventually take. Mine is my DD and I want 5.9 power without having to give up my '97. My 5.2 isn't dying any time soon so I have time to do it right.
zj97ltd is offline
post #19 of 27 Old 08-14-2013, 09:39 AM Thread Starter
David97
Mines not dying, shes still strong for the most part, just leaking almost every where. So instead of being without a vehicle to fix it all, it's just easier to swap in my case. I do beat the piss out of my jeep though. I am not easy on her at all... But she stays strong, reliable, and pulls hard. Just almost every seal is leaking lol
I'm thinking about maybe selling the 318, or rebuilding it, then building it up mildly. After the 360 is in of course. However we will get to that part later don't the road.
David97 is offline
post #20 of 27 Old 08-14-2013, 09:46 AM
zj97ltd
You could always do a "lo-po" 408. Nothing too destructive with a ton of torque. Run on cheap gas, maybe 9.0:1 compression.
zj97ltd is offline
post #21 of 27 Old 08-14-2013, 11:07 AM
CatSplat
1994 ZJ
And I think lastly (at least the only other thing I really need clarification on) is the ECU. Some say I "need" a 98 5.9 ECU. Others say keep the 318's as it'll work without issue. I believe I read on a thread Ratmonkey said you can use the stock 318 ecu, without issues, but recommends getting it tuned. However you really wont see many issues without a tune. SCT Tuners are out of stock as of right now anyways so that'd have to be put off for now. The other option for ECUs I read was a mopar performance ecu, but seeing as how hard those puppies are to find, I'm thinking the 318 ecu is what ill be using.
Well, to run a '98 ECU you'd need to convert your '95 to OBDII - no easy task. I can tell you I've been running a 5.9 using a stock '94 5.2 ECU for years with no problems. I changed to the 703 injectors shortly after install.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #22 of 27 Old 08-14-2013, 11:24 AM
HighLonesome
Plan on new heads. Yours may be ok, but at least you won't be surprised if they are cracked.
post #23 of 27 Old 08-14-2013, 11:27 AM
HighLonesome
New crank, pistons, rods. Custom block machining.
How about a hi-po 360? Aluminum heads and 10:1 compression.
post #24 of 27 Old 08-14-2013, 11:53 AM
zj97ltd
Yeah but then you have no choice but run hi octane.
zj97ltd is offline
post #25 of 27 Old 08-14-2013, 12:57 PM Thread Starter
David97
I only run premium 91+ anyways lol
Sent from my SCH-I535 using JeepForum
David97 is offline
post #26 of 27 Old 08-14-2013, 12:57 PM Thread Starter
David97
Another reason why I'm gonna completely break it down and rebuild it lol
David97 is offline
post #27 of 27 Old 08-14-2013, 12:58 PM Thread Starter
David97
Good to know. No issues whatsoever with the stock ecu?
David97 is offline
