Quantcast 5.9 swap Q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.9 swap Q's
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 11-20-2009, 08:36 AM   #1
rustynail
Location: Vancouver, British Columbia, British Columbia
5.9 swap Q's
Are 5.2 and 5.9 GC exhaust manifolds the same?
Do 5.9 GC's have the same restricting exhaust as the 5.2 GC?
Any tips to make this swap go as smooth as possible? (5.2 out yesterday)
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline   Reply With Quote
Old 11-20-2009, 08:51 AM   #2
squashman702
Mongo-fabbed
squashman702's Avatar
5.2 and 5.9 manifolds are the same. There are (93 or 94, not sure?) stock manifolds that flow better, but are probably not worth your time to track down and swap.
5.9 tailpipe is 2.75", but is not mandrel bent. Get a Kolak tailpipe instead.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote
Old 11-20-2009, 08:54 AM   #3
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
yes, exactly the same
Ask Kolak about the exhaust. I know the niner is bigger.
What are you swapping in?
HighLonesome is offline   Reply With Quote
Old 11-20-2009, 08:59 AM   #4
rustynail
I've got a 2002 RAM 5.9 complete with everything you see here and more.
- Russ
Old 11-20-2009, 09:04 AM   #5
HighLonesome
Sweet! How many miles on it?
Old 11-20-2009, 09:13 AM   #6
rustynail
85,000 miles. Do I have everything I need?
- Russ
Old 11-20-2009, 09:21 AM   #7
HighLonesome
Yep, and more
I'd do the intake plenum gasket and any leaking seals while its out.
Old 11-20-2009, 09:27 AM   #8
JeepOrvis97
One of 2733 :)
JeepOrvis97's Avatar
Is there a problem with the starter being on the driver side in the ram 5.9 when swapping these?
My Classifieds
JeepOrvis97 is offline   Reply With Quote
Old 11-20-2009, 09:28 AM   #9
rustynail
I recently replaced the drivers side motor mount so I don't want to replace it again. I read somewhere that it can be modified. Is this true? If so, what do I need?
- Russ
Old 11-20-2009, 09:30 AM   #10
rustynail
I had planned on using my stock transmission unless someone has made one of these work?
- Russ
Old 11-20-2009, 09:38 AM   #11
JeepOrvis97
One of 2733 :)
Ah, and don't know.
My Classifieds
Old 11-20-2009, 09:47 AM   #12
HighLonesome
Easy, nothing to worry about...all you need is washers or more preferably some round hollow stock.
Old 11-21-2009, 07:40 AM   #13
ratmonkey
Living dead mod
ratmonkey's Avatar
yeah, step out the mount with washers, you'll see what you need to do once you get it in there.
as for the dodge tranny, here's your list of parts to make it work.
hedman tight tubes block hugger headers. no other header will work with no modifications and no manifold will work period. the sanderson block huggers work with frame notching, there are no others that work.
custom y-pipe
relocate starter wires
dodge or fully custom tranny mount
if using dodge tranny mount, custom crossmember, if using custom tranny mount use your stock cross member or custom if you like.
novak shifter or custom shifter brackets for the tcase.
preferrably the dodge tcase that came with it, don't know the input shaft length that dodge may have run.
ratmonkey is offline   Reply With Quote
Old 11-21-2009, 10:11 AM   #14
redhatman
I am just finishing up my 4.0-5.2 swap, was your 5.2 worn out? Why are you replacing? When I was researching before my swap I found the 5.9 was obviously better, but not worth my non existant "extra" college kid money.
-Pat I'm 19, and getting my hands cut while learning
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
Looking for quality Jeep parts? www.ironrockoffroad.com
redhatman is offline   Reply With Quote
Old 11-21-2009, 11:09 AM   #15
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It was a lot easier to actually lower the engine into the jeep with the front tires flattened...more room and then we lowered it through the motor mounts. With the egine lower than the mounts, you have much more room to run wires, tighten those irritating little bolts and connect vacum lines. Then lift it up and bolt her up. I didn't have to remove the radiator at all.
I did replace all seals (new motor came with them). I bought a replacement radiator from Oreilly's...great deal. Before you go to crank it up, PM me and we'll talk.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Glock Forum
