5.9 Swap - Page 2 - JeepForum.com
post #16 of 18 Old 09-21-2013, 08:29 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by CatSplat View Post
Yes, nobody said anything about using a 5.2 flexplate with a 5.9, that'd be pretty stupid. I was careful to note in my post that I was using the flexplate from the 5.9, not the 5.2. The ovaling is because there was a very slight bolt pattern difference between the early 5.2 and 5.9 torque convertors, and it's a heck of a lot easier and cheaper to oval a hole than to buy an early 5.9 torque convertor for a 46RH.
Yep. Sorry if I misunderstood you. So you modified a symmetric weighted flexplate to bolt up to an offset torque converter. To clarify...
All Chrysler switched from offset to symmetric torque converter/flexplate around '96.
'93 -early '95 5.2 ZJ -> offset torque converter/flexplate
late '95 - '98 5.2, '98 5.9 ZJ -> symmetric torque converter/flexplate
5.9 flexplates do not interchange with 5.2 flexplates because of balancing
HighLonesome is offline
post #17 of 18 Old 09-21-2013, 07:22 PM
CatSplat
1994 ZJ
No worries, I'd say you've probably got that figured out.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #18 of 18 Old 09-22-2013, 06:08 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Take lots of pics on your swap. Big demand for pics of the swap, before, during, and after.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
