5.9 Swap - JeepForum.com
post #1 of 18 Old 06-28-2013, 03:28 PM Thread Starter
JakeC132
5.9 Swap
Has anyone done a 5.9 swap to a zj that isn't obd2? i have a 95 and was looking into it. Was wondering what problems people ran into and what the donor vehicle was (98 zj or ram truck) please let me know what you found
JakeC132 is offline
post #2 of 18 Old 06-28-2013, 03:56 PM
dnuccio
http://www.jeepforum.com/forum/f13/z...ml#post3020645
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 18 Old 06-28-2013, 06:41 PM
CatSplat
1994 ZJ
About as straightforward as swaps come. I used a '94 Ram 5.9 block/heads/crank/flexplate with the 5.2 E/I manifolds and cam. On OBD1 it's pretty much plug and play, minus the motor mount and ovaling one hole on the flexplate. The 5.2 computer has no problems running the 5.9, although I eventually upgraded to the 703 injectors anyway. You'll end up reusing a bunch of stuff from the 5.2, notably the accessory bracket and a few other bolt-on things, if you use a Ram 5.9 as they're different.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #4 of 18 Old 06-28-2013, 08:08 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Don't oval a hole in the flexplate. That can cause an imbalance. Spend the few extra bucks and get the right flexplate.
HighLonesome is offline
post #5 of 18 Old 06-28-2013, 10:26 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I did the 94 5.2 to 5.9 swap. Just the parts from the FAQs section. New parts, don't half way do it.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 18 Old 06-29-2013, 10:48 PM
CatSplat
1994 ZJ
An imbalance in what? The flexplate? We're talking maybe a gram of material removed here. I ovaled mine, no problems whatsoever.
The Jeep of Theseus
CatSplat is offline
post #7 of 18 Old 09-20-2013, 10:04 AM Thread Starter
JakeC132
do you know if it's the same or harder if the donor vehicle with the 5.9 is obdii? Can i still use my 46rh transmission? also has anyone bored to a 408?
JakeC132 is offline
post #8 of 18 Old 09-20-2013, 10:12 AM
dnuccio
Doesn't matter what the 5.9 comes out of, you reuse your 5.2 wiring harness. If you have emissions, you'll need to reuse the passenger side exhaust manifold and intake manifold from your 5.2 so you can retain the EGR system, if the 5.9 you get isn't set up for it. You can reuse your 46RH transmission
R.I.P. Ratmonkey
dnuccio is offline
post #9 of 18 Old 09-20-2013, 11:41 AM
zj97ltd
I don't want to cause bad juju with the mods, but there are a bunch of 408's on thespeedfreaks.net.
zj97ltd is offline
post #10 of 18 Old 09-20-2013, 12:13 PM
Aceladriver
go by Hunter's post in FAQ.
One of the best and simplest write-ups yet...
Originally Posted by CatSplat View Post
... . You'll end up reusing a bunch of stuff from the 5.2, notably the accessory bracket and a few other bolt-on things, if you use a Ram 5.9 as they're different.
Is the Ram accessory bracket different from ours?
I never heard that - thought it was only the power steering bracket and pump that was different?
If you don't have to pass emissions you can use your early TB an sensors but leave the late intake on there and make a blanking plate for the pass side exhaust manifold, or use a late ZJ manny.
....Can i still use my 46rh transmission? also has anyone bored to a 408?
You don't have a choice really.
It's either the RH or a 5speed, LOL. (early PCM isn't going to run the late ZJ RE series trannys)
And yes there's several ZJs running around with stroked 5.9 motors running off the early PCM.
... and ovaling one hole on the flexplate. ....
This is the amount that would need trimming on the flexplate.
Not ideal but really not enough to affect anything - better to get the right flexplate if you can do it though.
BTW per Martin Saine that bit of grinding doesn't matter til you get upwards of 400 - 500HP. Then you'd definitely want a non-ovaled FP.
Just for fun here's the 98 ZJ passenger side manifold vs the OBD1 manny.
It should be pretty easy to make a blanking plate with simple tools - but as said above ^ you'd want to stay with the stock setup if you have to pass emissions.
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline
post #11 of 18 Old 09-20-2013, 01:17 PM
CatSplat
1994 ZJ
That's a good question, my 5.9 was completely in pieces when I got it and mostly in boxes. I assumed the (different) accessory bracket it came with was from the Ram the motor was out of, but you know what they say about assumptions. It's entirely possible it was some random bracket the seller tossed in the box.
The Jeep of Theseus
CatSplat is offline
post #12 of 18 Old 09-20-2013, 02:18 PM
HighLonesome
Yes there is that gram and...
The 5.2 uses a 'zero balance' flexplate because the motor is internally balanced. The externally balanced 5.9's flexplate has balance weights welded to it. You really should match the 5.9 harmonic balancer to weighted flexplate.
post #13 of 18 Old 09-20-2013, 07:23 PM
Aceladriver
Definitely right. You'd have to keep it matched, but that's not the issue about the hole.
I 'believe' it's like this:
Most late Magnums (5.2 and 5.9) were the 90 degree bolt pattern flexplate, but the early 5.2 had the offset pattern fp, so I believe you'd have to do that clearance to match the late 5.9 flexplate to an early 5.2 tranny (well, torque converter)
That's why a 98 5.9 will bolt to a 44RE TC no prob, but you'd need that clearancing to use that same 5.9 on an RH.
The alternatives are to use the late 46RE converter on the RH (for some reason I thought that didn't work, but I'll take Hunter's word for it) - assuming you have access to one, or if you happen to be getting a stall converter they should be able to match whichever pattern you have.
Then if it's a stroker build 5.9 motor you go back in the other direction. Most stroker kits are neutral balance so you need to use the 5.2 damper and flexplate.
You can go with an aftermarket damper - even SFI approved ones, but I've never seen an aftermarket SFI flexplate for our motors. Not with the window wheel we need for the CKPS
post #14 of 18 Old 09-20-2013, 11:30 PM
CatSplat
1994 ZJ
Yes, nobody said anything about using a 5.2 flexplate with a 5.9, that'd be pretty stupid. I was careful to note in my post that I was using the flexplate from the 5.9, not the 5.2. The ovaling is because there was a very slight bolt pattern difference between the early 5.2 and 5.9 torque convertors, and it's a heck of a lot easier and cheaper to oval a hole than to buy an early 5.9 torque convertor for a 46RH.
The Jeep of Theseus
CatSplat is offline
post #15 of 18 Old 09-21-2013, 05:31 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I'm sure that if you are only going from 220 to 265 HP, on oval here s short cut there won't matter. I went from 220 to 375 HP. I did not shortcut anything. I also didn't have over heating issues.
I did not reuse the plug wire loom and burnt through two plug wires. So, I bought new wires, new loom and vroom, vroom.
It is embarrassing when you don't do something right and it sounds or looks like crap.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
