5.9 serpentine belt... help! - JeepForum.com
post #1 of 3 Old 12-27-2007, 09:44 AM Thread Starter
aletheuontes
ok guys... my first thread and I need some help because this is driving me crazy!
I got my 5.9 in February 07 and about a month later, the serpentine belt started squealing. I used some belt conditioner and that helped for about a day, then it started back up. After a few weeks, the squeal only got worse... so I finally replaced the tensioner. This lessened the noise, but the squeal was still present. The local garage suggested replacing the belt, so I did and it was fixed! Or so I thought...
Not too long after this, my rear-end gave out so the jeep was parked for a few months. But I just put a new rear-end on it and am driving it again (yay!). But now, after driving about 200 miles, the stupid belt is squealing again!!!!!!!
WHY???
The only thing I can figure now is that I have a pulley that is causing the belt to wear unevenly....?
Please help!
aletheuontes is offline
post #2 of 3 Old 12-27-2007, 10:12 AM
micifus
Original GC'er
micifus's Avatar
Very well could be your water pump. With the belt off check the shaft to the WP see if there is any play
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #3 of 3 Old 12-27-2007, 10:27 PM
Nurburgringer
Nurburgringer's Avatar
could also be the idler pulley and/or tensioner pulley bearings are shot. They are pretty cheap at Rockauto.com and easy to replace, I just did both on my 5.9 as a preventative measure at the same time I did the water pump (Pepboys) and ASP underdrive crank pulley (Summitracing.com) to replace my bent stock one.
Obviously a new belt at the same time is also a smart move.
Kurt
Nurburgringer is offline
Serpentine Belt Nofear6372 ZJ Grand Cherokee Forum 8 05-16-2008 09:41 AM
Serpentine Belt Bricolage ZJ Grand Cherokee Forum 1 04-13-2008 03:24 PM
serpentine belt chadburgwald ZJ Grand Cherokee Forum 1 08-23-2006 05:34 AM
Serpentine belt on WJ. rrubio ZJ Grand Cherokee Forum 9 01-06-2006 06:50 PM
Do i need a new serpentine belt? 98ZJBlack ZJ Grand Cherokee Forum 7 10-06-2004 10:55 AM
