5.9 roof rails on a 93? - JeepForum.com
post #1 of 17 Old 10-18-2007, 07:49 PM Thread Starter
CLNinja
CLNinja's Avatar
anyone know if a 5.9L roof rails and crossbars mount to the same holes as a 93 Limited?
i want to put the newer style rails on because mine rattles but i do not want to drill new holes
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #2 of 17 Old 10-18-2007, 08:15 PM
alivenkickin28
i would think they would but not sure -- same body
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #3 of 17 Old 10-18-2007, 08:16 PM Thread Starter
CLNinja
CLNinja's Avatar
yeah thats what im thinkin... but i wanna know for sure
Matt
CLNinja is offline
post #4 of 17 Old 10-19-2007, 03:04 PM
Scottso699
2006 WK
Not sure if they will fit - but as an FYI - the roof rails on a 5.9 are the same as the ones on a Dodge/Plymouth/Chysler MiniVan from the same year period. My parents had a 1996 Plymouth Voyager and it had the same roof racks as mine did. As for holes lining up - just use self taping screws and scilicon to seal up the old holes if they don't line up.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #5 of 17 Old 10-19-2007, 08:44 PM
nbjly
Awhile ago somebody had one on egay and said that it would fit any ZJ but you would have to drill different holes, dunno how accurate -
nbjly is offline
post #6 of 17 Old 10-20-2007, 05:10 AM
Aceladriver
Matt, good news on a definite answer - sort of!.
I have a 93 ZJ with the roof rack removed out in the driveway. About 30 feet away from it I have my 5.9's complete roof rack sitting under the back porch. I'd be glad to grab the 5.9 rack and line it up on the 93 to let you know for sure.
Problem is, I have to leave for work now so I wouldn't be able to test fit it and get back to you til later this afternoon or early evening.
Off hand I'm pretty sure it would fit but nothing beats a test fit.
If you don't have a definite answer by later in the day, like from someone that's actually swapped them, shoot me a PM to remind me.
John
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline
post #7 of 17 Old 10-20-2007, 10:00 AM
alivenkickin28
there ya go its done..... lol
post #8 of 17 Old 10-20-2007, 05:20 PM
Aceladriver
Actually it is!
Matt,
Just came back in from the back yard. OK, here goes...
I'd say it's an easy bolt on. There's a minor difference but it shouldn't be enough to matter.
I laid mine over the existing nut-serts but they have screws in them so I didn't actually bolt it down. It did sit flat enough to get a good idea of what's going on.
I took a chair around the Jeep and inspected the lineup of all the holes with a light.
Number and location of holes front to rear is the same on both and the rack holes are slightly slotted anyway.
Side to side, the distance between the left and right rows on the 93 measure at about 1/4 inch narrower than the 98 5.9 holes! May have to do with the sunroof being available on later years or something (sunroofs weren't available on the early ZJs were they?) or for all I know it could be a minor quality control issue.
So, from what I see that 1/4" difference is meaningless.
I flexed the rack around as much as possible (since it wasn't bolted down) and it appears you can easily get that 1/4 inch you need out of the normal play in the slider "blocks" and/or a slight flex of the crossbar.
Or, if you look at pic 770 below, a view of the inside of the 5.9 rack channel with a ruler over it, you could eliminate most of the difference by drilling the holes a size or two larger than they are. Pics aren't that great, the sun wasn't cooperating.
Top front view
http://i182.photobucket.com/albums/x...ofHPIM0762.jpg
Left front
http://i182.photobucket.com/albums/x...ofHPIM0764.jpg
Right rear
http://i182.photobucket.com/albums/x...ofHPIM0761.jpg
Right front
http://i182.photobucket.com/albums/x...ofHPIM0758.jpg
View of 5.9 channel w/ ruler
http://i182.photobucket.com/albums/x...ofHPIM0770.jpg
Hope that helps - John
post #9 of 17 Old 10-21-2007, 12:21 AM Thread Starter
CLNinja
CLNinja's Avatar
thanks alot for taking those pictures.. im definately wanting to get a 5.9 roof rack to put on my 93 now... im so sick of the rattling... its now on the list right after my 4.5" lift and 242 or 231 swap
Matt
CLNinja is offline
post #10 of 17 Old 02-13-2008, 02:10 PM Thread Starter
CLNinja
CLNinja's Avatar
Just to update this a little
the part numbers are
right side - 5FP78DX9
left side - 5FP81DX9
I had the dealer check to see if those part numbers were used on any other vehicles and he said those are exclusive to the 5.9 limited grand cherokees and that they are discontinued
so they are NOT the same rails as the Plymouth/dodge/chrysler minivans.. .they look similar but are not the same
Matt
CLNinja is offline
post #11 of 17 Old 02-13-2008, 03:37 PM
Marcos
Mopar released a fix for the rattling roof rack. Anyone tried it? It involves 4 clips, one to go in each "foot" to take up the slack. I bought a set, but I can't figure out how they go in, and the illustration in the TSB is of no help
Marcos is offline
post #12 of 17 Old 02-13-2008, 03:53 PM Thread Starter
CLNinja
CLNinja's Avatar
how much was it?
Matt
CLNinja is offline
post #13 of 17 Old 02-13-2008, 04:27 PM
a70eliminator
On the subject of roof racks, how the heck do the cross supports come off? I have a parts jeep with a good rack and I was wanting to add the two extra cross braces to my driver. I may even use them for another mod if only I can get them off, I'm thinking the side rails need to come off first or at least one of them.
a70eliminator is offline
post #14 of 17 Old 02-13-2008, 04:49 PM Thread Starter
CLNinja
CLNinja's Avatar
nope... there are two little caps that screw on to each end of the rails... take those off and slide the crossbar right off
Matt
CLNinja is offline
post #15 of 17 Old 02-13-2008, 04:52 PM
a70eliminator
It's that easy
Thanks, really I'm not an idiot, just spoiled.
SRT Roof Rails? Who's got'em? gsxr150 WK Grand Cherokee & XK Commander Forum 6 05-30-2008 01:04 AM
Roof rails ISUzj ZJ Grand Cherokee Forum 2 04-25-2008 01:38 AM
Roof Rails rhythmace WK Grand Cherokee & XK Commander Forum 1 12-27-2007 01:10 PM
Flat roof rails vettercr86 WK Grand Cherokee & XK Commander Forum 4 05-24-2007 09:30 PM
'01 vs '02 roof rack cross rails + want to buy cross rails... NoLimitsLimited ZJ Grand Cherokee Forum 2 01-17-2006 01:18 AM
