5.9 questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.9 questions
Jeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!JcrOffroad: New XJ Rear Crusader Bumpers available!
Unread 06-22-2012, 09:35 PM   #1
OnAll4sZJ
5.9 questions
Looking to pickup a 9er. What should I be looking for as far as problems. I know my way around the 4.0s, but not the 5.9....
What issues should I look for? Water pumps seem to be common and most have 180-250k miles. Are the 5.9s as reliable as the 4.0?
OnAll4sZJ is offline   Reply With Quote
Unread 06-22-2012, 09:38 PM   #2
Jerbear0612
5.9s are pretty reliable from what I've heard. Just look or worn out parts and normal maintenance items like you would any other car and you should be set. Best of luck
Jerbear0612 is offline   Reply With Quote
Unread 06-22-2012, 09:41 PM   #3
JasonStebbins
JasonStebbins's Avatar
Check the plenum gasket for oil leaks, very common in the 8 cylinders. Do some figure eights to check for a bad viscous coupler. Watch the temperature gauge when you go for a test drive, I hear they like to overheat from neglected basic maintenance.
JasonStebbins is offline   Reply With Quote
Unread 06-22-2012, 09:48 PM   #4
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
What Jason said.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 06-22-2012, 10:08 PM   #5
OnAll4sZJ
Bad vc would mean it would bind or hop right?
Plenum gasket? Is that a V8 thing or am I having a duh moment?
Unread 06-22-2012, 10:10 PM   #6
DNFJ
PAVEMENT POUNDER
DNFJ's Avatar
Yes sir.
00 XJ Sport(August 2012-Present) 4.0L - 156k, 6.5" IRO Adjustable Arm Lift, LMP Front Bumper, RC Double Sheer Track Bar, RC Quick Discos, Bilstein 5100s, IRO HnT SYE, Braided SS Brake Lines, 1" TC Drop, HiLift, Trimmed Fenders, Cherry Bomb, 33" BFGoodrich A/T on Eagle Alloy Recoils, Safari Snorkel, Safari Basket, 6x Hella 500, Autopal Harness + 80/100w H4 Bulbs
Thundercracker Build Thread
Built Not Bought #704
Past Jeeps:
93 ZJ Laredo(Jan 2011-April 2011) 5.2L - 98k, Stock - Totaled
96 ZJ Laredo(April 2011-August 2012) 4.0L - 138k, Cowl Intake, Rancho 9000 Series, 2" Spacers, 31" Baja MT Widetracks - Sold
Monstaliner: http://monstaliner.com/
Iron Rock Offroad: http://ironrockoffroad.com/
DNFJ is offline   Reply With Quote
Unread 06-22-2012, 10:14 PM   #7
OnAll4sZJ
Found 2 pretty closedor about $2k. Both have around 220k miles
Unread 06-22-2012, 10:25 PM   #8
JasonStebbins
Tell them $1500
How is the rust underneath? Don't be surprised to see 16 bad control arm bushings.
Unread 06-22-2012, 10:55 PM   #9
OnAll4sZJ
Tell them $1500
No rust. Not much here in the south.just high miles and normal defects for a 15 year old jeep. VIC and axles. Found one with 133k for 4k but the front axle is shot. Something about a seal is blown.
Unread 06-22-2012, 11:18 PM   #10
mrclark25
1994 ZJ
wow, you guys are lucky.
i have been watching CL, ebay, and autotrader for a 9er for the past 4 months. only 1 has popped up. 160k, $4900.
|_|0|_|
|_|_|0|
|0|0|0|
mrclark25 is offline   Reply With Quote
Unread 06-22-2012, 11:32 PM   #11
OnAll4sZJ
Where you at? I talked to a guy tonight just to say he had a nice lifted niner. Then he is like well I do have a stock one for sell for $1800. 235k. There 2 with 100 miles of Atlanta for under 2 grand and 20+ under 5k. Most of them are ghetto boys or soccer moms.
Unread 06-22-2012, 11:56 PM   #12
mrclark25
1994 ZJ
central nebraska ... seems like all jeeps are overpriced here, but they have good reason to be: they are about the best winter vehicle, and the winters here can be bad.
|_|0|_|
|_|_|0|
|0|0|0|
Unread 06-23-2012, 12:32 AM   #13
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The plenum gasket is under the intake on the V8s. If they start to leak or crack, you'll start burning oil and see white/ bluish smoke each time you accelerate.
Hunter
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.3661
Unread 06-23-2012, 06:45 AM   #14
frankcougar
I might have one for sale in a month for much less than that. I'm about 4 hours away from you.
1998 ZJ 5.9 Limited White 187,XXX miles
frankcougar is offline   Reply With Quote
Unread 06-26-2012, 07:48 PM   #15
timbre
I'm in SW suburb of Chicago and have original 5.9 with only 56K and best condition you'll find in Platinum. Runs perfect mechanically. Paint needs touch-ups and driver seat small tear along seam due to sun. Have other cars so only use each sparingly. Buying another new GC when I sell this one. Looking for $7000. Dealer offered $5500 already after checking it out. Waiting to find new Silver Overland w Saddle interior which they can't locate locally.
'98 Platinum ZJ 5.9 Ltd
timbre is offline   Reply With Quote
