5.9 overheats!!!!! Going crazy!!!! - JeepForum.com
post #1 of 17 Old 01-12-2014, 01:02 PM Thread Starter
wickedkingszj
I have a 98 zj with a 5.9l 165k and it constantly overheats.
Info on Jeep:
I have replaced the plenum pan gasket, intake gasket(which were horrible), thermostat, burped cooling system for hours on end with numerous gallons of coolant, E-fan is direct wired on high at all times.
No matter what the temp is outside, no matter what manner I drive (highway, off-road, city), the jeep overheats, heat stops being hot and the overflow bottle boils!!!
I have tried everything to burp the cooling system and I always have the same outcome steam and boiling the overflow bottle.
I'm going crazy over here!!!
Any help is appreciated!!!
wickedkingszj is offline
post #2 of 17 Old 01-12-2014, 01:10 PM
kachink
What temps are you getting on the guage?
Are you running a proper coolant mix or just water?
For coolant to actually boil in the expansion tank it's got to be really hot (I don't recall the temp). Plain water will boil in the expansion tank at normal operating temps.
kachink is offline
post #3 of 17 Old 01-12-2014, 01:15 PM Thread Starter
wickedkingszj
I run typically 60% coolant 40% water but it doesn't matter either way...would a head gasket allowing exhaust gases into the Copland cause this issue?
post #4 of 17 Old 01-12-2014, 01:45 PM
jeeepguy
jeeepguy's Avatar
Had a '97 that did the exact same thing. Ended up being a cracked head. Replaced them both with new ones and problem solved.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #5 of 17 Old 01-12-2014, 01:45 PM
PolkaPower
Did you replace the radiator cap?
PolkaPower is offline
post #6 of 17 Old 01-12-2014, 02:26 PM Thread Starter
wickedkingszj
Brand new radiator cap installed same issue
post #7 of 17 Old 01-12-2014, 02:54 PM Thread Starter
wickedkingszj
A few things to add:
When it runs at normal temp 180-220 the idle drops very low almost stalls and I have heat momentarily
Then after a drive around the block it will all of a sudden start blowing cold air and the temp gauge rises.
If I rev the engine to about 3500 rpm the temp will drop 20-50 degrees then I let off and I have heat for a few minutes but it will blow cold eventually and start over heating?
Could the water pump be to blame? There are no signs of a typical failed water pump...pully is good and solid and spins freely, no leaks whatso ever around the pump...
If I have to replace heads or head gasket I'm going to stroke this engine I believe...any hints or tips as to what would be a good setup?
post #8 of 17 Old 01-12-2014, 03:12 PM
PolkaPower
A bad water pump can cause the coolant to boil. So can a bad head gasket.
post #9 of 17 Old 01-12-2014, 05:17 PM
Snowfan2
Sounds like a head gasket.
1. Scan for codes
2. Do a compression check with all plugs out, throttle held open with screwdriver and fuel pump relay and coil wire disconnected. Post results.
3. Is there ANY oil in your coolant recovery bottle? If so, watch for little bubbles bubbling into bottle from overflow tube. =head gasket.
4. If you have a low cylinder do a leak-down test or go to NAPA and get what they call a block tester to confirm head gasket. It samples the gas in the radiator and indicates exhaust leak into coolant.
5. Have you blown any hoses?
Fix your fan, it helps nothing running on high full time. If you are in a cold environment it can cause problems.
Sounds like you have more than 1 issue going on. The scan for codes and compression check should sort it out. Compression check and leak down kit at Harbor Freight for about 35 bucks each. Block test at NAPA FOR 40+-.
Snowfan2 is offline
post #10 of 17 Old 01-12-2014, 06:50 PM
s99
I just fixed my overheating problem I had for a week. I was driving with the temperature gauge passing the third quarter (engine smoking). I know you've done this already, but I ended up leaving the rad cap and bleeder open for about 15 minutes running. It blew out sooooo much air and bubbles while filling the rad. Engine stayed cool ever after.
Does the temperature drop while the heater is blowing?
s99 is offline
post #11 of 17 Old 01-13-2014, 05:48 AM
newfieZJ
I've only used 2 gallons give er take a little . Where's your coolant going ? Makes it look like a head/gasket issue . I agree with Snowfan . Could be a cracked head also . If compression tests show an issue , and you do end up taking it apart , be sure to have the heads checked for cracks . It would be a lot of wasted time to do a gasket job twice .
Only thing that confuses me here is no mention of white smoke or coolant smelling exhaust Problem seems bad enough , these symptoms should appear . No mention of leaks on the floor , or anywhere on the engine so the typical by-pass(maybe replaced during plenum job) should be fine . Another typical leak is the timing-cover gasket . It would have to be blown completely to the point a leak would be obvious . I have one leaking for 3 yrs and still no issues other than a top up every 6 months or so . If you don't ave a puddle from it , I don't see it being an issue .
You need that compression tested
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #12 of 17 Old 01-13-2014, 06:26 AM Thread Starter
wickedkingszj
No notice of coolant in exhaust
No leaks present at all inside or out
Coolant bottle will boil as soon as it's up to temp, it bubbles violently when the jeep is hot
There has been a time or 2 where the upper radiator hose blew off the radiator and in turn emptied the cooling system
Also I have flushed the heater core and get good flow in and out
Gonna try compression test...
post #13 of 17 Old 01-13-2014, 06:34 AM
newfieZJ
Since you mentioned blowing off the upper rad hose , are you sure the rad is OK ? That kinda pressure could indicate the head issues or a plugged rad IMO .
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #14 of 17 Old 01-13-2014, 07:12 AM
KJK
Now put a new radiator under it.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #15 of 17 Old 01-13-2014, 08:32 AM
Snowfan2
I have a head gasket leaking and have no coolant smell or fog in exhaust. My compression numbers look about like this...
1. 160
2. 130
3. 162
4. 155
5. 164
6. 163
7. 168
8. 159
2 is way out of spec. I plan to fix it this week.
The NAPA kit is the fastest and easiest way to find out if it is head gasket.
http://www.napaonline.com/Catalog/Ca...006_0361073538
Autozone has it also http://www.autozone.com/autozone/acc...er=391378_0_0_
Blown hose and bubbling/boiling in coolant bottle hint at head gasket. There are some videos on youtube that might help you figure it out. Search head gasket, leak etc.
Snowfan2 is offline
