5.9 liter drives like a u-haul - JeepForum.com
post #1 of 11 Old 08-02-2009, 07:00 PM Thread Starter
joshuatchandler
Just got my first jeep a few months ago. I've had small sporty cars until this jeep so I understand that there will be a big difference in street performance. But, I have also driven larger vehicles and mine seems to perform terrible on streets and highways. When I hit a bump on the interstate I feel like I'm gonna crash and most likely die. It feels like the car wants to jump off the road. The best way i can describe it is like driving a u-haul.... what could be the problem?
joshuatchandler is offline
post #2 of 11 Old 08-02-2009, 07:05 PM
jutgin
cheap lift, worn tires, worn shocks, needs alignment, ball joints, tie rod ends. There's more I'm sure. You may need to take it an alignment shop and have them check it all out.
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #3 of 11 Old 08-02-2009, 07:13 PM Thread Starter
joshuatchandler
thanks man. I definitely have worn tires. I did not know that could cause this problem. it also needs an alignment. it doesn't have a lift and i just had the ball joints and axles replaced.
The dude i bought it off of was a mechanic and he "jack legged" a few things just to sale it. he put split boots on it so the first time it took it in the woods mud got in there and ruined the ball joints. He also somehow rigged up the power steering and the pulley fell off and pump screwed up... but i still love my purchase, i'll never go back to a car again.
post #4 of 11 Old 08-02-2009, 07:15 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Post his name up on here so no one takes their jeep to him to fix!
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #5 of 11 Old 08-02-2009, 07:22 PM
jutgin
^^^^^^^ X2
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #6 of 11 Old 08-02-2009, 07:37 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
It could be a number of things.
I really think you need to paint us a clearer picture. What exactly happens? The Jeep wobbles? wanders? bumpsteer? death wobble?
What you take it in for an alignment they will tell you if there is anything wrong (from what they can tell) before they try to align it.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #7 of 11 Old 08-02-2009, 07:52 PM Thread Starter
joshuatchandler
my steering wheel shakes around 60 but i assume that is tires and/or alignment. what i'm talking about is when i hit a bump at high speeds it just feels really loose and it will immediately pull one direction or the other.
"bump steer" and "wobble" sound the most relevant. It's definitely not death wobble. My dads truck had that, i never got in it again.
post #8 of 11 Old 08-03-2009, 12:04 AM
Mikedc3
Track Bar, Tie Rods, Steering Box, Control Arm Bushings all need to be checked.
Have someone rock the steering wheel back and forth while you look at both ends of the track bar and all tie rods. Look for play in them. Get a good look at the control arm bushings for any cracks\tears etc.
Sounds like your front axle may be wandering after you hit a bump which results in the pulling.
Mikedc3 is offline
post #9 of 11 Old 12-22-2009, 05:26 PM Thread Starter
joshuatchandler
steering stabilizer fixed it.
post #10 of 11 Old 12-22-2009, 05:40 PM
reedjor
Steering stabilizer can also mask a bigger problem and make you think it's fixed... like running dual steering stabilizers on a sloppy lift.
reedjor is offline
post #11 of 11 Old 12-23-2009, 07:57 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
There are a couple of things that running a 98 year model Jeep will need to have replaced.
Shocks
Swaybar bushings or a new bar and bushings like an Addco bar
Steering stabilizer
alignment
Those should get it up and riding much better.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
ESP & Tow/Haul button problems 07WKLtd WK Grand Cherokee & XK Commander Forum 3 11-24-2007 05:47 AM
Pulling a U-HAUL Car Dolly??? tjsgrecc ZJ Grand Cherokee Forum 18 11-13-2007 06:24 AM
Towing U Haul Trailer btoz ZJ Grand Cherokee Forum 1 04-13-2007 06:09 PM
Tow Haul Mode Martin610 WK Grand Cherokee & XK Commander Forum 6 11-09-2006 01:38 PM
Preparing my WJ for a long haul... LEDFoot ZJ Grand Cherokee Forum 14 03-04-2005 12:11 PM
