5.9 limited AC blows warm at idle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.9 limited AC blows warm at idle
Save 17.76% for the 4th of july with ruffstuff specialtiesIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!
Unread 06-28-2015, 05:38 PM   #1
Jd_joe
I just picked up a 1998 5.9 limited. A/C blows cold at speed. I did notice after idling for a while waiting for a car wash, it was suddenly blowing cold. Normally thought, it blows warm at idle even after driving for some time and coming to a stop. I do hear the high e fan kick in some times. Not sure if its doing it every time it's supposed to or if thats related?
Jd_joe is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 06:31 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
With the engine cold, ac off, hood open, start the jeep. The efan should be off. Hit the AC button, the efan should kick on at high speed. If it doesn't you either have no high speed, or the pressure switch on the AC line is dead and not kicking the fan on with the AC.
The high speed is supposed to come on with AC, it sounds like for one of the above reasons it isn't and after you idled for a while the low speed kicked on, pulling air through the condenser and giving you AC>
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 08:52 PM   #3
Jd_joe
Turns out you're right. Started vehicle with A/C off. Kicked A/C on, compressor kicks in and was cycling every 30 seconds roughly. Fan was doing nothing. I took off for a drive. Cools at speed. Fan also seems to cycle when coolant temp gets over 210. I assume its the low speed fan position I'm hearing? How can I diagnose the issue? Fan, wiring, relay, low freon level, etc....?
Unread 06-28-2015, 08:52 PM   #4
StPaul59
Im pretty sure the AC only activates the low speed on the fan..
StPaul59 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 09:04 PM   #5
SchizophrenicMC
No, the A/C activates the high speed fan setting. That's pretty well standard.
1997 Grand Cherokee Orvis Edition
Because tacky green leather is SUPER COOL
SchizophrenicMC is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 09:56 PM   #6
kg6mov
Hears the voices
kg6mov's Avatar
Yep AC should be kicking on the high speed of the fan. Low speed comes on at about 210.
The first step would be to see if the high speed kicks on at all. If you disconnect the lower radiator hose switch and jump it with a piece of wire and then start the jeep it should kick the fan on on high. If it doesn't then check that the relay triggers then check power to motor, then replace motor. If it does turn on then you may just need the ac pressure switch.
Unread 06-29-2015, 05:42 AM   #7
Jd_joe
Awesome! Just the advice i needed. I'll get to it. Thanks!
Unread 06-29-2015, 05:51 AM   #8
Marcos
On this application, it kick on the low speed. The wiring diagram in the FSM is wrong. I've "dissected" one of these wiring harnesses and the A/C switch is spliced in parallel with the upper hose switch, which controls the low speed.
This chart is correct, however.
Marcos is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 06:50 AM   #9
KJK
My fan runs on the low speed when the AC is on.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 12:07 PM   #10
jeepjeepster
Same here.. Fan on low with A/C on.
My fan kicks on low at around 195F. Much sooner than that diagram says.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 05:09 PM   #11
Jd_joe
Ok, so which switch should i jump to simulate coming on with the a/c? When the fan does come on, it sounds like high. Possibly no low?
Unread 06-29-2015, 07:40 PM   #12
StPaul59
No. Not standard for the 98.
Unread 06-29-2015, 07:41 PM   #13
StPaul59
Low speed is the upper hose sensor.
Unread 06-29-2015, 08:58 PM   #14
Jd_joe
I jumped the upper hose wiring harness. Nothing at the fan. Can i swap the high and low relays side to side and see if the low side of the fan takes off?
Unread 06-29-2015, 10:32 PM   #15
kg6mov
Hears the voices
kg6mov's Avatar
Yes, the relays should just swap. I would just put a finger on the low speed relay while somebody hits the AC button. You should feel the click.
