5.9 "liftgate ajar" intermittent electrical issue - JeepForum.com
post #1 of 3 Old 08-13-2011, 11:19 AM Thread Starter
Adwex
Hey all,
Recently my 5.9 is getting a "liftgate ajar" indication when the liftgate (rear hatch) is closed. This is a pain in the neck because:
a) I can't leave the doors locked or the alarm horn will sound (even though it's disarmed...but that's another subject)
b) The interior lights are on or flashing on/off at a random rate (extremely annoying and dangerous at night). When leaving the vehicle, I have to disconnect the battery so it doesn't drain.
I have the wiring diagrams, and it implies that there is a short to ground somewhere in the circuit. The diagram also shows that the "liftgate" switch is in parallel with the "liftglass" switch, so it could be either circuit.
Any suggestions where to begin before I start troubleshooting? Any particular components with a history of failure?
Adwex is offline
post #2 of 3 Old 08-13-2011, 02:35 PM
kachink
When mine did this the switch that sensed if the lift glass was open was loose in its housing. A couple of whacks with a punch while holding it in a vice snugged it up and solved the problem.
kachink is offline
post #3 of 3 Old 08-13-2011, 07:00 PM
MeanGreenZJ
What the guy above said. If you don't want to whack it or replace it, simply disconnect the plug going to the lift glass switch. To test it push and pull on the glass and see if the VIC beeps at ya. Lastly to stop the interior lights from flashing on/off till you can deal with the problem just press on the cargo light to turn it off.
MeanGreenZJ is offline
2008 WK "Liftgate Open" message MI_Offroad WK Grand Cherokee & XK Commander Forum 19 05-14-2017 06:25 AM
08 Overland HEMI with intermittent "no starting" issue eric02910_HEMI WK Grand Cherokee & XK Commander Forum 18 11-27-2011 10:56 AM
"Liftgate Ajar" message... Mike97ZJ ZJ Grand Cherokee Forum 5 02-20-2011 09:27 AM
Liftgate ajar sensor 97JGCL jdjeep ZJ Grand Cherokee Forum 2 02-24-2007 09:00 PM
burning "smell" issue and "gas pedal vibration" issue in 07 gc laredo beepbeep13 WK Grand Cherokee & XK Commander Forum 4 01-08-2007 06:06 PM
