5.9 Harmonic Balancers OE style on ebay - JeepForum.com
post #1 of 16 Old 02-17-2014, 03:09 AM Thread Starter
newfieZJ
Just wanted to let the 5.9 owners know there are OE style HB's available . I have not seen these around as most now have the pulley cast on them in 1 pc . They are fine , and I do have one installed , but , these are , more original . Besides , if you ever need to remove the new style , you need another puller
Price is $65 and even shipping to Canada , only $14 more . Great deal IMO . Fast shipping , good ebayer , 100% positive feedback . I sure like mine . The yellowish color is reflection off the bench , it`s very clean , pic don't do justice . Link below pics
http://www.ebay.com/itm/181204281062...84.m1439.l2649
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #2 of 16 Old 02-17-2014, 04:04 AM
Timo_90xj
Timo_90xj's Avatar
The one I got from Rockauto (the only place I could find one back then and also do international shipping) certainly isn't OEM quality. It's one of those with the 1- piece design, can't remember the manufacturer though. I get a slight vibration at 1500rpm (+/-50rpms) that wasn't there before.
Thanks for the info, I probably gotta buy one of these if it's better than the 1-piece design versions. I hate the vibe, especially because I stay on that RPM range quite often when driving. Downside is, I used the old OEM pulley/ HB "frame" to fab a tool so I can keep the crankshaft from rotating when doing certain work on the engine
***Under construction***
Timo_90xj is online now
post #3 of 16 Old 02-17-2014, 07:02 AM
PolkaPower
I got the updated Mopar one piece design from Kolak and it's vibe free. Can't use a crows foot puller on it though. You need a 3 claw. Can't say how easy it is to get off. I haven't needed to remove it yet. The original was real easy to remove.
PolkaPower is online now
post #4 of 16 Old 02-17-2014, 08:34 AM Thread Starter
newfieZJ
$30 shipping from rockauto to my door . I have a one pc on my slate 5.9 , no issues after 4 years . Warped pulley was a concern of mine initially but turned out ok , Timo , maybe you got some shipping damages Either way , I like these better .
I should order one for my future 5.9 , you know I will have another one soon ,
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #5 of 16 Old 02-17-2014, 10:45 AM
Timo_90xj
Timo_90xj's Avatar
I looked at the same thing, that the one- piece version might be a pain to pull out. Not too much room, and I'd hate to need to remove the radiator and A/C condenser. IIRC there was hardly enough room to pull the old one out with a 3-jaw puller that I had shortened.
As far as the vibrations go, I don't think it had suffered any damage. Everything rotates exactly like should (I've measured with a dial gauge and nothing there). Probably just poor quality with the inner-outer-ring placement with each other. I couldn't bother sending it back and getting a new one because the vibes aren't huge. It's noticable, but not overly bad to destroy anything.
I will have to order one of those OEM- design versions. Just to be sure... you never know when you realize another niner has mysteriously appeared on the driveway
post #6 of 16 Old 02-17-2014, 12:42 PM
CatSplat
1994 ZJ
I've got a one-piece pulley on mine (wish these had been available when I got it!) but you can remove it without pulling the radiator. I use a 2-jaw puller from Princess Auto and it gets the job done - it's tight, but it works. The two-piece is a lot easier to get out using a steering wheel puller though.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #7 of 16 Old 02-17-2014, 12:46 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
That's pretty neat. I might just buy one of these as a spare. I have a one-piece on there now and I'd really like to go back to the OE style if/when the current one comes off.
In the garage: M1 4bbl
McCloudsZJ is offline
post #8 of 16 Old 02-17-2014, 12:57 PM
PolkaPower
The one piece is OE. It's the updated version. The one you see here is the original version. They don't make them like that anymore as far as I know.
post #9 of 16 Old 02-17-2014, 01:33 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Then I like the OOE version. The one-piece is not my favorite.
post #10 of 16 Old 02-17-2014, 02:28 PM
PolkaPower
post #11 of 16 Old 02-17-2014, 02:48 PM
Timo_90xj
Timo_90xj's Avatar
I see an excuse for a wider main pulley for the supercharger drive belt..
post #12 of 16 Old 02-17-2014, 02:51 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
Maybe... Or something like this.
http://chucker54.stores.yahoo.net/momabipuset.html
post #13 of 16 Old 02-17-2014, 04:33 PM Thread Starter
newfieZJ
Kinda like that . . I bet the sale price reflects the availability of the OE dampers . Might have to order this
newfieZJ is offline
post #14 of 16 Old 02-20-2014, 01:06 PM Thread Starter
newfieZJ
Out with the old . This one was living on borrowed time
1995 Orvis build
1988 MJ build
newfieZJ is offline
post #15 of 16 Old 02-20-2014, 01:39 PM
Timo_90xj
Timo_90xj's Avatar
Wow, that looks pretty bad. Couple years ago when my HB failed, it looked a lot better than that (heck, it was still all black ). When I took off from traffic lights behind another car - FRRRRMMMM... I saw a weird looking strip land on the pavement behind my Jeep, and it took me probably two seconds to realize what just happened.
I couldn't even stop there, but had to drive another couple miles with the dismembered harmonic balancer. The wobbles evened out to almost normal @2700rpm though When I found out the sweet RPMs, I could actually drive it home from after work
