Quantcast 5.9 Fan ( old subject, new question) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.9 Fan ( old subject, new question)
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 04-14-2009, 08:46 AM   #1
98zjteen
The low speed on my electric fan no longer works. So now I switched the wires so that the high speed runs when the low is supposed to be on. This fix has worked for a while, but we all know that it wont last and it draws alot of power. My question is this: Can i directly fit the taurus fan motor into the shroud of the 5.9? The motors look like they have the same dimensions, but I am concerned that they are not the exact same. Also, is it the same amperage and voltage, or am I going to have to increase the gauge of the wiring? Any info would be a great help. Thanks Guys. Also, if you know where I can just get a 5.9 motor, since we all know those are just laying around let me know
98zjteen is offline   Reply With Quote
Old 04-14-2009, 09:08 AM   #2
FPKites
ZJjazzyJim
FPKites's Avatar
They do have the same motor, but mounting is a bit different, and the wiring harness is most definitely not the same.
So, to answer your question, yes it would be a good replacement, though not exactly a direct replacement.
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Old 04-14-2009, 09:24 AM   #3
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Sorry to link to another site, but great info on 5.9 fan motor. See post 13 at the bottom....
http://www.jeepsunlimited.com/forums/showthread.php?t=436320&highlight=taurus+fan
HighLonesome is offline   Reply With Quote
Old 04-16-2009, 08:50 AM   #4
98zjteen
Huge help! thanks
Old 04-16-2009, 09:48 AM   #5
darkfour
I had this problem on mine and did the high/low speed wire swap too. Eventually the fan bearings seized (a week before Xmas) and the whole lot nearly caught fire. Smoke was pouring out from under the hood just as I pulled in to the yard at home. I ended up buying a new fan assembly from the stealership at a huge cost over $700 I think. If you go that route then they were on back order and took a couple of weeks to arrive. They had to ship two as the first one arrived and the fan shroud was badly cracked in delivery. I was without the Jeep for nearly a month waiting for the parts to arrive, but I guess Xmas and New Year in between didn't really help
darkfour is offline   Reply With Quote
Old 04-16-2009, 09:56 AM   #6
HighLonesome
You could have bolted in a clutch fan and shroud and been able to drive it.
I carry a clutch fan and shroud in my vehicle at all times in case of emergency. If the efan dies, you are stuck. No ifs, ands, or buts.
Glock Forum
