5.9 Electric Fan Set Up on 5.2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.9 Electric Fan Set Up on 5.2
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEFS: Wranger BRIGHT License Plate LED! Just $3! Great valueKOR Name Your Price Sale
Unread 02-28-2015, 07:15 PM   #1
NewTo98JeepGC
I was about to put a Mark VIII fan my ZJ and I find a 5.9 LTD with electric fan and sensors at upper and lower radiator hoses. I took the harness and fan altogether.
Wondering how to connect the harness to my 5.2L. Or only the fan is useful?
NewTo98JeepGC is offline   Reply With Quote Quick reply to this message
Unread 02-28-2015, 07:16 PM   #2
kg6mov
Hears the voices
kg6mov's Avatar
The fan is great, I would recommend not using the niner wiring though.
Here's mine, niner fan and shroud, not niner wiring.
http://www.jeepforum.com/forum/f13/n...2/index12.html
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 03-01-2015, 07:55 PM   #3
NewTo98JeepGC
Yep. The one I got is exactly like that, with flaps.
So the harness are not compatible to regular ZJ wiring?
Unread 03-01-2015, 08:08 PM   #4
kg6mov
Hears the voices
kg6mov's Avatar
It's compatible, but not worth the effort IMO.
I looked at using the wiring from the niner when I did mine but the Volvo relay package and the BMW dual temp switch fit my needs better. If you have access to a JY niner for the AC hose with the two switches that would simplify the AC high speed override (I don't have one) and make it behave more like a stock efan.
In general I don't like the two temp switch housings, the way the ignition interlock works, or the ac pressure switch for high speed override. The relays are beefy and work well, but the volvo package was more to my liking.
"Coulda had a V8!"
96 build thread
Niner build thread
Unread Yesterday, 07:22 AM   #5
Maine1994ZJ
I used a Niner fan, a PDC I scavenged from the JY to hold the parts store relays I bought, and a BMW 2 stage thermo switch.
'93 V8 ZJ Mountain Goat Edition.
Maine1994ZJ is offline   Reply With Quote Quick reply to this message
Unread Today, 04:08 PM   #6
NewTo98JeepGC
Is the Mark VIII fan stronger than the niner fan?
