is a 5.9 driveshaft interchangable - JeepForum.com
post #1 of 11 Old 12-05-2008, 10:03 AM Thread Starter
shdybrady19
Will a 98 5.9 front driveshaft mate up with my 5.2 set up? Both have quadradrive and both have the cv axle.
shdybrady19 is offline
post #2 of 11 Old 12-05-2008, 10:26 AM
JeepOrvis97
JeepOrvis97's Avatar
Yes
4567890
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #3 of 11 Old 12-05-2008, 10:31 AM
CLNinja
CLNinja's Avatar
should be a direct swap
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #4 of 11 Old 11-10-2013, 08:48 PM
98cherokeeJeep
Hate to tell ya but i dont think it is...I have a 97, grand 5.2. Just picked up a rear end from a 98 grand 5.9. My drive shaft does not fit the yoke on the rear end!!! its too small, and im stuck and dont know what to do lol...I bought the right sized u joint but the u joint is too big for the driveshaft
98cherokeeJeep is offline
post #5 of 11 Old 11-10-2013, 08:56 PM
CatSplat
1994 ZJ
Firstly, the OP was from 5 years ago and was asking about a front drive shaft, not a rear.
The 5.9L rears used a 1330 U-joint, while the 5.2 and 4.0 used a 1310 joint. You can use a 1310-1330 hybrid conversion U-joint to fit your 5.2 drive shaft to the 5.9 rear end.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #6 of 11 Old 11-10-2013, 09:10 PM
98cherokeeJeep
hey ya sorry about that, didnt mean to sound like an ***.
Where do i get that u joint? I went to my local parts store Lordco, we found the ujoint that is used in the 5.9 rear driveshaft. Anyways i picked it up but it is too big for my rear driveshaft, so i suppose obviously it is made for the thicker driveshaft.
so when u say hybrid conversion u joint what is this, is it specialy made for this purpose??? more info please thanks
post #7 of 11 Old 11-10-2013, 09:12 PM
98cherokeeJeep
also im in canada, Maple ridge bc...if i can get one around here that would be great i need my jeep back on road asap
post #8 of 11 Old 11-10-2013, 09:21 PM
Snowfan2
CatSplat...I needed those numbers for the conversion joint, thanks.
Snowfan2 is offline
post #9 of 11 Old 11-10-2013, 09:22 PM
Snowfan2
Yes. Same shaft length and connections. Installed one a few days ago.
Snowfan2 is offline
post #10 of 11 Old 11-12-2013, 11:57 AM
KingtheZJ
search for "1310 to 1330 crossover ujoint"
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #11 of 11 Old 11-12-2013, 12:34 PM
CatSplat
1994 ZJ
Basically the hybrid joint has two 1310-size ears to go into the 5.2 drive shaft, and two 1330-size ears to go into the 5.9 D44A yoke. They're not a wholly uncommon thing, Lordco ought be able to order one in if they don't already have one in stock.
The Jeep of Theseus
CatSplat is offline
WK and XK Parts interchangable thecommander WK Grand Cherokee & XK Commander Forum 3 04-11-2017 03:03 AM
4.0/4.7 oil pump interchangable ? mpmjeep ZJ Grand Cherokee Forum 3 01-07-2009 09:55 AM
Interchangable grills cheroKeeKid333 ZJ Grand Cherokee Forum 2 12-07-2008 08:48 PM
Interchangable Spacers? toby42 ZJ Grand Cherokee Forum 2 06-08-2007 05:23 AM
Front Differential interchangable?????? Kalisto2k1 ZJ Grand Cherokee Forum 9 03-17-2005 08:13 PM
