5.9 Cooling Fan causes extreme voltage drop when it turns on - Page 3 - JeepForum.com
post #31 of 31 Old 11-22-2012, 01:15 PM
zachjf
Originally Posted by MeanGreenZJ View Post
If the fan runs in a Taurus with a 50 amp fuse, it's safe to say that it will keep running with anything higher, like a 75 amp fuse.
You do raise a good point about the fast blow fuses tho, wish I had the proper equipment to test it cause its gotta be a really quick spike, that or the larger fuses actually take a bit longer to fully burn through, enough time for the draw to subside
Needs parts?
PM
or
zachjf is offline
