5.9 - Coolant Leak, upgrade parts! - Page 2 - JeepForum.com
post #16 of 23 Old 03-08-2012, 04:24 AM
newfieZJ
Originally Posted by MilanJeep View Post
Regarding the MSD coil, it's actually pretty funny, the Jeep guys are the only people who seem to think this thing makes power.
Without trying to sound like a dick, there is no way in hell your lifted 5.9 gets 21 mpg highway at 75 mph. 15-16 at 60 mph maybe, but 21 mpg at 75 is not happening on a lifted SUV.
Back to the plugs, I have never heard of anyone recommending platinum plugs except for the people at the parts store. Copper is a much better conductor than platinum. The double platinums are simply a longevity feature, but many would suggest that double, triple, and quad tipped plugs are a marketing gimmick.
Who said the MSD coil gives more power ? I said the box does ...
My 5.9 isn't lifted . Welcome to hell , lol . That's a 95 Orvis in my avitar . I know , it's hard to tell the difference , ha ha . I can't get better than 14-15 with the 95 but happy with that considering the lift .
Champion dble platinums . They can market them however they like , they work good , and get the best mpg's from my jeep I've ever seen . They accually pay for themselves with the savings . Again , I wouldn't push something that I haven't proven works
newfieZJ is offline
post #17 of 23 Old 03-08-2012, 11:29 AM
Smokey1r
Originally Posted by Candymancan View Post
It isnt an o ring kit, its a replacement metal tube for the heater bypass. However its a short dodge version "ours are long" but the O ring is what you want on it.. The only way to get these "special" o rings is from that tube kit, or from a waterpump box or the felpro gasket kit. Your waterpump should have 1, and i bought 1 of those tube kits, took the o ring off and returned it for another one so i had 3 o rings lol. I tore one, the 2nd went on fine and i have a 3rd extra. The part number on autozone's website is 56399 , or just type in heater bypass tube and pick the 2nd one
The oil pan doesnt have to come off as i said. The timing cover is held on by 2 bolts through the oil pan. Take them off, take the timing cover off and the oil pan has a lip hanging open. Take a rag and cover the openeing so you dont get old gasket material or something in your oil.. When you reseal everything clean the old gasket of oil and dirt and put RTV over it so it wont leak when you put the timing cover back on.
Yes i replaced the front main seal on the timing cover for the crankshaft. No i didnt buy the sleeve kit for it. I forgotr what the sleeve thing is for but mine didnt need it. Just get the fel-pro gasket kit for the timing cover and water pump without the sleeve. Oh and that kit will have a o ring as well lol
I also had 2 o-rings, one in the water pump's gasket kit and the other in the timing cover gasket kit. All i did was clean the end of the heater bypass tube of all rust and debris, slip the o-ring on and slathered on the RTV and plugged it in, no fuss no problem. Of course i let everything sit overnight so it cured up nice and tight before i replaced the coolant and fired the engine up doing the initial leak check..... all was well.
Smokey1r is offline
post #18 of 23 Old 03-10-2012, 09:57 PM Thread Starter
ech0sh4y
2008 WK
Ordered the Hughes plenum kit tonight. I'll be taking off the intake tomorrow and seeing how bad it looks.
Also I was going to order my other parts (still working on it right now)...
As for the double roller timing set, I noticed the part number in the picture is an option (auto zone part) as well as an alternate part number. Looks to be two different sizes, P/N: 78103 shows that it's .250" diameter chain, while P/N: 78203 shows that it is .222" diameter chain. I did a quick search for the 78103 chain and this eBay listing show for LA blocks only, would this not work on Magnum blocks?
Also does anyone else recommend a timing chain tensioner? The guys at speedfreaks said that it is best to replace the thrust plate... didn't make sense, here is a link to one:
https://hughesengines.secure.nharmon...=&partid=11213
~ Brian
2008 WK Overland CRD
ech0sh4y is offline
post #19 of 23 Old 03-10-2012, 10:24 PM
Candymancan
i wouldnt bother with the chain tensioner.. I just put a stock timing chain back on mine, no double roller just a normal chain... Considering my old chain after 120k miles didnt have much slack in it i didnt see the point.. The new chain should last another 100k +... But then i was also on a money constraint
Candymancan is offline
post #20 of 23 Old 03-10-2012, 11:02 PM Thread Starter
ech0sh4y
2008 WK
So this is what I have on order thus far:
- Plenum kit from hughes
- Plenum plate
- Intake gasket
- TB gasket
- T-stat (not sure on brand)/seal
- New hardware
- Valve cover gaskets
- Timing Chain Gasket Set
- T.C. Gasket
- T.C. Seal
- Water pump gasket
- Harmonic Balancer
- Idler pulley
Still waiting to hear back about the double roller chain size then I'll order that. Other wise I think this should get me back together. Please keep in mind that I have replaced the plugs and cap/rotor so far. Thought about porting the kegger but I'm going to steer clear as it does not seem to net much. I will clean up the injector holes however.
I thought about putting a cam in at this time and some roller rockers and upgrading the 5.9.. But future projects. Just need to get it back on the road.
~ Brian
ech0sh4y is offline
post #21 of 23 Old 07-30-2012, 06:20 AM
newfieZJ
Did you find out about that chain ?
I contacted Cloyes . They did confirm mine would work but couldn't confirm it would fit under the cover , they didn't say it would not .
I used the same parts source (MOPAC) and it's the only one they list for a SBC . The LA block and magnum blocks are the same , heads are different .
I still have yet to get at the jeep to repair it , things just keep getting in the way . I also have to figure out the Dorman harmonic balancer removal puller set-up . I have to get it done very soon , I'll be leaving for work again in a few weeks .
Just thought I would update this thread and will again after the t-chain has been installed .
newfieZJ is offline
post #22 of 23 Old 01-25-2014, 03:27 PM
StPaul59
This part number says it only fits 1991 or older Dodge..
Originally Posted by newfieZJ View Post
Timing Chain
Attachment 359517
StPaul59 is offline
post #23 of 23 Old 01-26-2014, 12:59 AM
newfieZJ
Installed , works just fine . Lots of LA block engine parts swap over to magnums
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
Timing Cover Coolant Leak (Parts?) GuessWho ZJ Grand Cherokee Forum 29 10-20-2011 07:15 PM
1998 awd GC coolant leak...when it wants to leak... swnee327 ZJ Grand Cherokee Forum 1 09-22-2011 08:55 PM
Coolant leak..... Well.... Coolant lake Shpuker ZJ Grand Cherokee Forum 5 08-29-2011 09:45 PM
Coolant Leak. Where is it going and how can I fix it? admeister86 ZJ Grand Cherokee Forum 12 09-10-2010 04:00 PM
WJ 4.0 Coolant Leak comptiger5000 ZJ Grand Cherokee Forum 13 03-04-2009 05:32 PM
