5.5 IRO Lift - JeepForum.com
post #1 of 5 Old 05-23-2013, 11:11 PM Thread Starter
blacktree4
5.5 IRO Lift
hey guys i know this has probaly been asked before but hell ill ask again. i plan on upgrading my 3.5 llift with IRO 5.5 longarm kit soon. I have the 249 tc but was curious if i should swap it out or if it needs be i rather not i dont mind the 4wd all time. also if i should worry about driveshaft angles, increasing the length or a sye? Overall im just looking for what i might run into for problems along the way lifting my zj this high and may be able to avoid beforehand. thanks!
blacktree4 is offline
post #2 of 5 Old 05-24-2013, 07:07 AM
ejschultz
ejschultz's Avatar
Opt for at least adjustable uppers in the rear. That'll let you dial in your pinion. IRO long arms have a pretty good amount of caster adjustment built in to the y-link. I don't think you'll have a problem with the front angle. The 249 should be fine with that lift. Also, ZJs generally don't require SYEs; Some are exceptions, however.
ejschultz is offline
post #3 of 5 Old 05-24-2013, 08:44 AM
WhiteOut
WhiteOut's Avatar
You'll need to address the front shaft, easiest and best method is to switch it to a u-joint style shaft.
WhiteOut is offline
post #4 of 5 Old 05-24-2013, 08:46 AM
ejschultz
ejschultz's Avatar
I forgot about that. My ZJ had a u-joint shaft for some odd reason. The PO was an old lady so I know she didn't swap it...
post #5 of 5 Old 05-24-2013, 09:53 AM Thread Starter
blacktree4
I have a u joint style driveshaft already in it so that should be fine. Thanks guy appreciate the info.
