5.5 inch lift - JeepForum.com
post #1 of 8 Old 04-03-2006, 07:24 AM Thread Starter
Ironworker28
5.5 inch lift
ok i changed my mind about the lift i was gonna do only 3 inches. Now ive decided to go with a 5.5in. Questions, what are all the componants i beed for everything to be good and straight and ride right and what are the biggest tires i can put on it? Thanks...oh yea its a 99GC limited
Ironworker28 is offline
post #2 of 8 Old 04-03-2006, 08:03 AM
Derek33
Derek33's Avatar
springs
front/rear track bars
controll arms
sway bar end links
extended break lines
maybe an sye or t-case drop kit
Derek33 is offline
post #3 of 8 Old 04-03-2006, 08:14 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
There is no rear trackbar...extended brake lines you'll need for sure...I am thinking about them at 4"...
3" will ride VERY differently then 5.5" btw...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 8 Old 04-03-2006, 01:08 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
http://jeepsunlimited.com/forums/sho...d.php?t=553856
Some of the issues you'll have to deal with.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 8 Old 04-03-2006, 01:24 PM
Derek33
Derek33's Avatar
yeah my bad on the rear track bar, i asumed you had a zj. my fault.
Derek33 is offline
post #6 of 8 Old 04-03-2006, 01:30 PM
TriggerHappy
springs
controll arms
sway bar end links
All that is correct minus the extended brake lines since it s a WJ. If you want it safe, consider replacing the front lower, front upper and rear control arms along with quick disconnect sway bars. Add an aftermarket steering stabalizer (OME) and shocks and you are good to go.
With 5.5, you are going to be at the absolute max you can go without a long-arm kit.
2000 WJ 4.0 @ 4.5" Rusty's 2.5 coils, Teraflex 2" spacers,
Rancho 9000 shocks, OME SS,
Rusty's adjustable track bar , full 3"
exhaust and BFG All- Terrain
265/75/16's.
TriggerHappy is offline
post #7 of 8 Old 04-03-2006, 02:19 PM
ArloGuthroJeep
Mr. Hyde!
Originally Posted by TriggerHappy
springs
controll arms
sway bar end links
At 4" I would do extended brake lines...I had to disconnect one of the clips holding my rear brake lines to the A-arm because they were being pulled against at max drop and my fronts are damn close to being too short.
post #8 of 8 Old 04-03-2006, 02:33 PM
gunthagunth
gunthagunth's Avatar
i have springs and im located in quincy if ur interested
oops theyre zj springs
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
Torn between 4 inch and 4.5 inch lift for my ZJ givemeazj ZJ Grand Cherokee Forum 21 08-07-2011 09:42 PM
4 inch springs on a 3 inch lift?? zj333 ZJ Grand Cherokee Forum 8 12-20-2009 05:02 PM
3 inch lift.. 1 inch bb? coopdc78 ZJ Grand Cherokee Forum 8 11-09-2009 07:03 PM
32s on 2 inch lift? G-Wagon00 ZJ Grand Cherokee Forum 16 02-09-2009 10:39 AM
2 Inch lift vs. 2 Inch Spacers jeep_05 WK Grand Cherokee & XK Commander Forum 19 06-06-2008 01:57 PM
