5.2L will crank but won't start97 - JeepForum.com
post #1 of 11 Old 09-09-2009, 01:56 PM Thread Starter
Dukota
97 Grand Cherokee died last night just as my son was pulling away from his friends house then wouldn't start. It will crank but that's it. Just prior to that it had been leaking some coolant from a leak in the radiator but appeared to have no other problems. Wasn't even overheating, was within the normal operating temp, according to him.
I guess my first mistake was letting my 19yo son drive MY Jeep. Transmission is out in his Oldsmobile Bravada though so he needed something to get to and from school.
I hooked up an OBD scanner but it will not connect so I don't know what sort of issues it may have.
Any thoughts on either the code scanner issue or the no starting issue? Haven't had an opportunity to check anything else out other than that there is fuel in the fuel rail.
Whoever dies with the most toys, wins.
Dukota is offline
post #2 of 11 Old 09-09-2009, 03:07 PM
JeepOrvis97
JeepOrvis97's Avatar
First off, you can pull the codes by cycling the key(without starting) on-off-on-off-on and it should show the codes in the odometer, then we'll go from there.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
post #3 of 11 Old 09-09-2009, 04:13 PM
LordHobbit
Does it have spark? Fuel? Air? Compression? Check and report.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 11 Old 09-10-2009, 12:19 PM Thread Starter
Dukota
I am off today so I am going to check all of those things right now. Just woke up, I've worked 134 hours in the last two weeks and needed to catch up on some sleep.
Dukota is offline
post #5 of 11 Old 09-10-2009, 01:06 PM Thread Starter
Dukota
One thing I've noticed is none of the instruments will move when I turn the key on. Shouldn't the guages, fuel, oil pressure, volt come on when the key is turned on? I've checked the cluster fuse and it's ok.
Dukota is offline
post #6 of 11 Old 09-10-2009, 02:03 PM Thread Starter
Dukota
Fixed it. It was a fricken 20 cent, 20 amp fuse that handles the body control module.
Dukota is offline
post #7 of 11 Old 09-10-2009, 05:42 PM Thread Starter
Dukota
ok, didn't fix it. Fricken 20 cent, 20 amp fuse keeps on blowing. Haven't made any changes to the Jeep but this just popped up all of the sudden. Any ideas?
Dukota is offline
post #8 of 11 Old 09-11-2009, 07:07 AM
LordHobbit
Gotta be a short somewhere, follow the wire and check. It's possible it rubbed until the insulation wore off. If you find the end of the wire and no bare spots, do a continuity check with ground.
post #9 of 11 Old 09-15-2009, 01:05 AM Thread Starter
Dukota
I would not even begin to know WHAT wivre to follow since it is the fuse block in the engine compartment
Dukota is offline
post #10 of 11 Old 09-15-2009, 07:23 AM
impuresoul2k3
A factory service manual is a godsend for following wiring. I recently installed a remote start/keyless entry system, and the FSM made it much easier.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #11 of 11 Old 09-24-2009, 11:47 PM Thread Starter
Dukota
Finally got a check engine light. Hooked up my code reader and got a code for and o2 sensor so I crawled under the Jeep and found the wires going to the sensor had dropped down onto the driveshaft and worn one wire thru and the stripped part of the plastic off of two others. A little snip, crimp and zip tie out of the way, reset the code and all is good. This one repair paid for the code reader I bought.
Dukota is offline
1997 5.2 crank but no start, need help with crank sensor replacement. titan66 ZJ Grand Cherokee Forum 8 01-28-2011 08:34 PM
Oil Leak from Crank Pulley/Crank Seal? maderj ZJ Grand Cherokee Forum 10 01-16-2011 08:21 AM
4.0 ZJ will not crank out of nowhere slagehammer ZJ Grand Cherokee Forum 2 11-21-2008 11:32 AM
96 ZJ won't crank jsaunder ZJ Grand Cherokee Forum 0 10-31-2006 11:46 AM
Crank Crank Crank goes the engine skier123 ZJ Grand Cherokee Forum 3 12-04-2004 10:01 AM
