5.2L V8 Grand Cherokee Main Bearings - JeepForum.com
post #1 of 8 Old 08-05-2009, 11:27 AM Thread Starter
aflan
I have a tired 1993 Grand Cherokee with a 5.2L V8 (ZJ?). It's oil pressure is good when the engine is cold but it drops to near zero when hot. The engine sounds good when it is first started (Cold). When the engine is hot there is a knock that sounds like a main bearing. Had a mechanic check the oil pressure to verify gauge readings and he confirmed the pressure drop and believes the main bearings are gone. He wants $2000+ to pull the engine and replace the mains and oil pump. I want to squeeze a few more miles out of her and I don't think it is worth pulling the engine and reworking the crankshaft etc. Can the main bearings be replaced without removing the engine? I know it's possible with the inline 6 cyl but is it possible for the V8?
This is just a play vehicle now since I've had it for 15 years.
Thanks for any advice
Allen
aflan is offline
post #2 of 8 Old 08-05-2009, 03:12 PM
driabyor
driabyor's Avatar
1994 ZJ
yes it can be done with engine in the vehicle.... just a few special tools.... as for 2 grand... might as well find a good used engine and replace the whole engine
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 8 Old 08-05-2009, 03:18 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Yes but its a bear of course.
Remove the oil pan and the bearing caps. You can tap the top half of the bearing out with a small wooden dowel until it spins enough to where the end sticks out. You can then gingerly use a punch to move it along the circumference of the crank. If you remove the timing chain (PITA), the frontmost top bearing half moves way easier. Chrysler makes a special tool for this onerous chore, but my dealer wouldn't sell me one.
HighLonesome is offline
post #4 of 8 Old 08-05-2009, 03:22 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
before you buy mains, be sure you don't need any oversize or undersize ones, that info will be on the crank.
ratmonkey is offline
post #5 of 8 Old 08-05-2009, 03:47 PM Thread Starter
aflan
Thanks for the replies.
Where on the crank would the bearing size be marked? I was under
the impression that the bearing would be marked on the OD.
Here is a nice writeup I found on another site:
http://www.cherokeetalk.com/forum/f2...oil-pump-3340/
It's a Main seal & Oil Pump replacement so I would have to add the bearing replacements. Nice pictures make it look almost doable.
regards
Allen
aflan is offline
post #6 of 8 Old 08-05-2009, 03:52 PM
HighLonesome
The Clevite bearings I used were marked, not sure about the stockers.
post #7 of 8 Old 08-05-2009, 04:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the bearings are usually marked for size, if it has worn off of the stockers, it will be located on the last counterweight on the crank. it's in code, don't remember the specifics, should be able to find it online.
post #8 of 8 Old 08-05-2009, 04:26 PM Thread Starter
aflan
Starting to look possible to me (and I haven't had any beer). It would be a big waste of effort if my crank is badly scored... but since it runs pretty well when it's cold, just maybe the crank isn't too bad. The compression is good so the upper end is fairly solid.
regards
Allen
aflan is offline
any advice on main bearings, upper shell says .001 sdowney717 ZJ Grand Cherokee Forum 15 11-07-2011 04:51 AM
Should I replace my main bearings while the oil pan is off? 02Lightning ZJ Grand Cherokee Forum 8 07-22-2008 07:19 PM
93 Grand Cherokee 4.0L Rear Main Seal iPlay1515 ZJ Grand Cherokee Forum 8 05-28-2008 05:24 PM
Is it time for new main bearings? Help!!!! tetatdo ZJ Grand Cherokee Forum 2 11-10-2007 05:19 PM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
