5.2L Overheating on stop and go traffic. - Page 2 - JeepForum.com
post #16 of 26 Old 09-09-2009, 06:06 PM Thread Starter
BayjiRaider
FINALLY!!! We found the problem!!! The radiator that I bought from Western Auto is one row only!!!, Mine (V-8) should be at least two rows! They don't want to exchange it! Nuts!!! I'm going with a three row rad now and the factory 195 degree t-stat , any suggestion my jeeper partners??? Different radiator?, t-stat?
BayjiRaider is offline
post #17 of 26 Old 09-09-2009, 06:10 PM
elmer_fud
I think the factory radiator was one row.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #18 of 26 Old 09-09-2009, 06:12 PM
WhiteOut
WhiteOut's Avatar
Originally Posted by BigE3 View Post
i beg to differ sir. if the system is overcharged the condensor wont be able to change the gas into a liquid when it cools because there is too much. and it wont be able to disburst that heat efficiantly. Sorry but I already been thru this problem. I had 80-100psi flux on the high and 40psi on the low. should be 20psi low and flux 60-80 on high. And the dash cooling went from 48 to 38 degrees.
So my A/C that is charged to factory spec is wrong? Despite the fact its ice cold and I dont overheat? Interesting.
WhiteOut is offline
post #19 of 26 Old 09-09-2009, 06:31 PM
rugermack
If it still runs hot, some vents in the hood might help.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #20 of 26 Old 09-09-2009, 06:44 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i wouldn't pay much attention to that guy.
the stock rad is only one row.
ratmonkey is offline
post #21 of 26 Old 08-08-2011, 06:47 AM
tylersjeep
1994 ZJ
help my jeep is over heating
I replaced the thermostat flushed the system, checked the spark plug, water pumps not leaking, I my heats not working anymore it just blows cold air, my car over heating 230F i'm getting bubbling and a boiling sound in my over full tank and its shooting up everywhere, i also put a new radiator in 8 months ago, I just order and new water pump and fan clutch....i'm just spending spending spending and it not fixing the problem, now i lost my heat wtf going on.
tylersjeep is offline
post #22 of 26 Old 08-14-2011, 02:37 PM
soopaghetto
this may sound like a real obvious question but how important is a complete shroud?
I just realize im missing the bottom half of mine (looks chopped off). still pulls a lot of hot air, though im guessing while in traffic, not a lot is going through the radiator but being pulled from the bottom opening?
soopaghetto is offline
post #23 of 26 Old 08-14-2011, 09:24 PM
tylersjeep
1994 ZJ
no one responds
its a waste of time to post stuff because the last three post i left on different forums no one responded to anything i said, its not a very helpful forum i had call a dealership to get info, and i fix my overheating problem...i hired a jack assss to put a thermostat in and he ****ed it up, i ended up fixing it myself, the guy drained out all the coolant and flushed it with a hose, and guess what he did not do and told me it was fine.......bleed the system when he was done so it keeped overheating and shooting up coolant everywhere. he was a jerk and shut off his phone because i said WTF did you do.
post #24 of 26 Old 08-14-2011, 09:34 PM
Dodgeram1989
1976 FSJ Cherokee
Periods help. Kind of hard to read.
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #25 of 26 Old 08-14-2011, 10:09 PM
blackjack12982
1994 ZJ
Both of you posted questions in a 2 year old thread. If you want actual results, make your own thread.
Definitely x2!
blackjack12982 is offline
post #26 of 26 Old 08-14-2011, 11:28 PM
soopaghetto
Definitely x2!
lol
Rear end clunk low speed stop/go traffic bhcva ZJ Grand Cherokee Forum 3 08-06-2010 11:53 AM
99 Grand Cherokee overheating when in heavy traffic, with or w/o A/C on roxygirl25 ZJ Grand Cherokee Forum 14 07-21-2009 11:36 AM
WJ Overheating in Traffic safarimike ZJ Grand Cherokee Forum 13 07-22-2007 10:59 PM
2000 JGC overheating when sitting in traffic. Joey P. ZJ Grand Cherokee Forum 60 07-26-2006 12:03 PM
How do i stop the car from overheating? annabelle ZJ Grand Cherokee Forum 11 01-12-2006 12:12 PM
