5.2L Overheating on stop and go traffic. - JeepForum.com
post #1 of 26 Old 09-06-2009, 11:34 AM Thread Starter
BayjiRaider
My Grand Cherokee 5.2L All Track is overheating! I need help!!!
It has a brand new radiator, new thermostat, new water pump, new fan clutch, new temp-sensor, new 18lbs. cap, no leaking, heads and head gaskets are OK. System has been bled and flushed. It runs on the 210 range, after stopping for about 10 minutes with the A/C on, it goes up to 250. It even have and extra electric fan on the front (pushing) Tempature here on the island is on the 80-90's range. The last thing I did was to eliminate the thermostat to see what happens, exactly the same again. Holy water in the radiator may be the answer? An exorcist job maybe? I NEED HELP!!!
BayjiRaider is offline
post #2 of 26 Old 09-06-2009, 11:45 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I left a rag inside my upper radiator hose one time. That'll get you to 250 also.
Is the shroud on? Sounds like you replaced anything it could be. There is a spring that goes inside the lower rad hose to keep it from collapsing. I doubt that's it, I'm just trying to think of anything else it could be.
HighLonesome is offline
post #3 of 26 Old 09-06-2009, 12:07 PM
driabyor
driabyor's Avatar
1994 ZJ
shroud is needed...
also no thermostat will let the water move too fast thru the radiator ,thus not cooling it.
a/c condensor may have enough dirt and debris on it to reduce air flow
bug screen... will reduce air flow
maybe a bigger radiator is needed
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 26 Old 09-06-2009, 12:33 PM Thread Starter
BayjiRaider
Fan shroud is OK, I'll steam clean the A/C condenser. Should I use the factory 190 deg. t-stat or maybe go down to 160 degrees??? Also some people said that it has to be Mopar, otherwise it will not work OK.
post #5 of 26 Old 09-06-2009, 01:32 PM
elmer_fud
the thermostat brand shouldn't matter. with the 160 thermostat you will get worse milage because the system is still in closed loop control (I think that is the right name)
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #6 of 26 Old 09-06-2009, 02:04 PM
driabyor
driabyor's Avatar
1994 ZJ
mine has a 180 in it ..... not me ....parts person gave me the wrong one.... runs fine.....
I just didn't look at it before install
Is the thermostat in correctly.... not backwards.
I don't know but some engines have reverse rotation pumps, I don't know if this is the case for 5.2
Is the belt routed correctly... i could be turning the pump backwards, don't know if this is possible..
is the belt tight.... tensioner within limits
5.2 liter 242 :)
driabyor is offline
post #7 of 26 Old 09-06-2009, 04:42 PM Thread Starter
BayjiRaider
I did clean the A/C condenser with a steam cleaner and degreaser and its doing a whole lot better!!! It looked clean but it was'nt! Thanks everyone specialy driabyor!!! You rock!!! Army, 101st Airborne 4ever!!! and jeeper until I die!!!
post #8 of 26 Old 09-06-2009, 04:46 PM
iluvtruenos
What about your viscous fan clutch? Does it freewheel for a while after you shut the engine off? You should be able to get it to spin about 90* after you push it, but if it does more than one rotation, then it's shot.
My Jeep is a chick magnet with reverse polarity.
2000 WJ, 4.5l, AX15, 242 D60/14b, 5.5" lift front, 7.5" rear. Ford Expedition rear coils, Ram 350 shocks, JKS, IRO Long Arms, cool Badlands flag thingy.
1987 XJ - Gone but not forgotten
iluvtruenos is offline
post #9 of 26 Old 09-06-2009, 05:10 PM
blackjack12982
1994 ZJ
I thought that was where you were from! Bayji was a complete s&*thole! 1st BN, right?
blackjack12982 is offline
post #10 of 26 Old 09-06-2009, 05:34 PM
BigE3
Im new here but this may help you out. You said you replaced the thermostat, do you think any of the gasket sealer may have blocked the bypass port. OR... and this may sound stupid.
Did you recharge you're A/C yourself. If you overcharge the A/C it will not be able to disburst the heat efficiantly because there is too much in the system. I had the same problem with overheating and found out that it Chrysler put out wrong information on fluid levels and dealers and a/c techs didnt know. So check these 2 areas and lemme know what you come up with. Hope it helped.
BigE3 is offline
post #11 of 26 Old 09-06-2009, 05:54 PM Thread Starter
BayjiRaider
I did eliminate the t-stat, tomorrow I'll be replacing it with the factory one. Blackjak, Bayji was really a s&*thole, 1st Bn, 187th Inf Bde. Rakkasans!!! 4Plt/918th MP Co.may-2005-may-2206 (Fob Summerall) I got blown twice, one on gasoline alley close to the Al- Fatah mosque , second on the Al-Saniyah check point!!! Still here, lost sight on my left eye, movement on my left wrist, little burns on my right arm, but still an MP Sgt. with the National Guard and driving my jeeps!!! Remember: All gave some, some gave all!!! Thanks to yo you guys, medics, I'm here today, you saved a lot of soldiers lifes. If nobody have tell you before. THANK YOU FOREVER!!!
post #12 of 26 Old 09-06-2009, 06:24 PM
elmer_fud
The AC system is different from the engine cooling system. Overcharging the AC will cause almost no change in the engine cooling.
Brian
post #13 of 26 Old 09-06-2009, 06:31 PM
BigE3
i beg to differ sir. if the system is overcharged the condensor wont be able to change the gas into a liquid when it cools because there is too much. and it wont be able to disburst that heat efficiantly. Sorry but I already been thru this problem. I had 80-100psi flux on the high and 40psi on the low. should be 20psi low and flux 60-80 on high. And the dash cooling went from 48 to 38 degrees.
BigE3 is offline
post #14 of 26 Old 09-06-2009, 07:21 PM
blackjack12982
1994 ZJ
I knew it! I'm in 1-187! Uhh, I definitely don't miss that place at all! We all lost too many there...
Good luck with everything! Happy Jeepin!
post #15 of 26 Old 09-06-2009, 11:04 PM
SILASPRIT
so you are saying that the condenser heats the air before it goes through the radiator? interesting.
-SOLD-
1997 Grand Cherokee 5.2 Limited - D44a Trussed 4.10 Gears - HP30 4.10 Gears - NP242 - IRO HnT - IRO Custom Drive Shaft - 4.5" lift - JKS Quicker Disconnects -
RC Front ADJ. Trackbar - IRO Rear ADJ. Trackbar - Rusty's Lower ADJ. CA's - Front tow hooks - Rear OE Hitch - T-Case Skid -
Gas Tank Skid - Bilstein 5125's - 31" MTR's - Magnaflow SS Muffler - 1.25" Wheel Spacers - Custom Rock Sliders - Cobra 19 DXIV
I am an Authorized IRO dealer!!
SILASPRIT is offline
Rear end clunk low speed stop/go traffic bhcva ZJ Grand Cherokee Forum 3 08-06-2010 11:53 AM
99 Grand Cherokee overheating when in heavy traffic, with or w/o A/C on roxygirl25 ZJ Grand Cherokee Forum 14 07-21-2009 11:36 AM
WJ Overheating in Traffic safarimike ZJ Grand Cherokee Forum 13 07-22-2007 10:59 PM
2000 JGC overheating when sitting in traffic. Joey P. ZJ Grand Cherokee Forum 60 07-26-2006 12:03 PM
How do i stop the car from overheating? annabelle ZJ Grand Cherokee Forum 11 01-12-2006 12:12 PM
