5.2l Grand Cherokee Engine Rebuild - Page 2 - JeepForum.com
post #16 of 40 Old 06-29-2012, 08:38 PM
edpmedic
Sorry I should have subscribed and crawled this thread. I would have said it isn't easy pulling the engine and Trans with a transfer case has one unit. I do suggest you be careful with the radiator. Now I thought you were rrbuilding it for a performance upgrade. Did you locate what cylinder was knocking. Or if it was a rod, or wrist pin, crank bearing before you took it apart.. Did you preform at least a compression test wet and dry, have vacuum readings or oil pressure reading?
To tear into a engine before at least determining a location of the knock or the condition of the engine is not a good way to go about this. If it was a very noticeable knock then maybe you will be lucky and see excessive wear or damage. At this point pull the heads. Check the ridge at each cylinder bore and look at the cylinders, before you pull the main or rod bearings. Has you rotate the crank you might feel a problem and determine what it can be. Them check crank end play before you loosen anything.
Put
Then I remove the ridge from the cylinders. After that I would plastigage each rod bearing and then main bearings.Write info down and check each one has I take it apart. Is there play to the connecting rod while attached to the crank? That could be your rod knock. I usually do the connecting rods first. At the same time pull them With the piston out of the cylinder. I then see if the crank turns free without the pistons attached. Check end play on the crank again. Then I plastigage the main bearings and check them. I also look at the pistons and rings for wear on the skirt and the condition of the rings.
From what I have read you already pulled the caps and are looking at the bearings. You see copper showing. Are we talking about the rod or main bearings? Is the wear in the center, sides, or half the bearing. Are there any lines or grooves in the bearings. By the way you have taken the oil pump off. You sure it was not a valve or lifter problem, but that would be tapping and not a knock.
Hope this helps and just take it slow write down measurements and if you need take pictures before you take it apart. Mark stuff that goes together and work clean. Of all things Safety first
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #17 of 40 Old 06-29-2012, 08:44 PM
dusterdude
Main bearings
dusterdude is offline
post #18 of 40 Old 06-29-2012, 10:05 PM
edpmedic
Main bearings.are crankshaft bearings
Mahatma Gandhi
edpmedic is offline
post #19 of 40 Old 06-30-2012, 10:10 AM Thread Starter
bmlarson12
I will try to check the clearances in the bearings soon.
bmlarson12 is offline
post #20 of 40 Old 07-06-2012, 09:47 PM Thread Starter
bmlarson12
It looks like it was probably a rod bearing or a carbon knock. I plan to do some little upgrades over time, but for now I want to get a good camshaft that will work now, and in the future with other upgrades. I am looking at two different ones. One is a good bit bigger, and will work well at low end, along with the higher end (HER0814AL). The other one is the Hughes Engines towing cam (HER9204AL). I know that I would also have to adjust the engine computer some for the larger one to work, but it does have a better range of rpm.
post #21 of 40 Old 07-08-2012, 11:01 AM Thread Starter
bmlarson12
I guess I am going with the HER0814AL because of the better rpm range it will work with.
post #22 of 40 Old 07-11-2012, 05:58 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Well, any pics yet? How's the progress going?
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #23 of 40 Old 07-15-2012, 07:36 PM Thread Starter
bmlarson12
Hunter
So almost everything is together. We finished with the engine yesterday and put it into the Jeep today.
post #24 of 40 Old 07-15-2012, 07:39 PM Thread Starter
bmlarson12
Here are some pictures of the changes that I made.
post #25 of 40 Old 07-15-2012, 10:46 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Looking great.
04 4.7 HO, limited
04 4.7 HO, Overland
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #26 of 40 Old 07-18-2012, 07:18 PM Thread Starter
bmlarson12
Everything is finished up now and I was able to drive it back home. There were some timing problems that I couldn't fix so we had a mechanic fix that. He also reset all of the old computer information with the old camshaft so it will be able to relearn the new cam. After a day it did have a small new problem. I believe the oil pressure sensor is going out. it is dropping to zero at idle but at about 1000 rpm it goes straight back to normal. It never made any sound at idle to indicate a problem, so I assume it is alright. Do these sensors tend to have problems after a while? I have seen several people having similar problems and I think they were normally just sensor problems.
post #27 of 40 Old 07-18-2012, 07:31 PM
Canyon411
Silly question but I assume you replaced the factory oil pump with a new high volume unit? It would be hell for a new engine rebuild to internally destruct from lack of oil pressure from an old pump.
Canyon411 is offline
post #28 of 40 Old 07-19-2012, 06:34 PM Thread Starter
bmlarson12
Yes I did use a new high volume oil pump.
post #29 of 40 Old 07-20-2012, 07:30 PM Thread Starter
bmlarson12
What controls the oil light? I am just not sure if it is the same thing that controls the oil pressure gauge.
post #30 of 40 Old 07-21-2012, 09:37 AM
ZJ1995
Originally Posted by mrclark25 View Post
i would cam it and if you have the money, find some headers to put on it.
higher performing heads would also be nice, but i don't know of any.
performance heads are sold by edlebrock, along with cam and whole top end rebuild.
The mind is like a parachute, it works better when open!
95 ZJ UNLimited upcountry suspension ::::: 98 ZJ ProComp Rims Needs a radio(SOLD)
95 XJ Fixed! (SOLD)... F.S. 4.0 I6 130k, 42RE trans and D35 3.73 gears
ZJ1995 is offline
5.2l , engine rebuild , magnum , performance
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
97 Jeep Grand Cherokee 5.2l rebuild help bmlarson12 ZJ Grand Cherokee Forum 16 04-19-2013 04:29 PM
Oil engine Castrol Edge is ok for Jeep Grand Cherokee WJ engine 3.1 VM Motori ? diogene ZJ Grand Cherokee Forum 0 11-11-2008 02:51 AM
Rebuild on an 02 Grand Cherokee mjbirner ZJ Grand Cherokee Forum 0 07-30-2008 09:26 AM
93 Grand Cherokee engine Black_cirrus ZJ Grand Cherokee Forum 2 01-02-2005 02:22 PM
