5.2l Grand Cherokee Engine Rebuild - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 5.2l Grand Cherokee Engine Rebuild
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiPoison Spyder DeFenders™ - "Tubeless" Jeep FendeJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 06-27-2012, 10:42 AM   #1
bmlarson12
I am currently rebuilding my Jeep's engine and would like to know if anybody has any advice on what can make it easier. Right now I am trying to get everything off of it to take the engine out, so I would like to have some advice with what could make that easier.
Later I would like to modify things in it a bit so I would like to know if there are any suggestions for ways to increase performance.
bmlarson12 is offline   Reply With Quote
Unread 06-27-2012, 01:11 PM   #2
bmlarson12
I have a lot of stuff off, but I don't know what to do about the ac.
Unread 06-27-2012, 01:46 PM   #3
PolkaPower
A turbo or supercharger will increase performance.
98 5.9 2"BB, Custom V-Tec mod, high performance muffler elves, alloy performance lug nuts, super high flow custom radiator cap, Ultralight unobtanium flywheel, stage 6 ultralight hydro tuned wiper blades(front), kevlar stickers
[QUOTE=JohnnyZJ;13325401]if its to tall for her to get into why don't you just install some running boards?[/QUOTE]
[QUOTE=HAMAR;13330720]I just gave her ironing board, she's not getting another board.[/QUOTE]
"What is best in life?
"To crush your enemies, see them driven before you, and to hear the lamentations of the women."
PolkaPower is offline   Reply With Quote
Unread 06-27-2012, 01:56 PM   #4
edpmedic
You could take the AC compressor off the brackets and leave it hooked up. Just move it out of the way has you remove the engine from the car. Same thing with the power steering pump. You remove it from the bracket through the holes in the front pulley. Three long bolts hold it in place from the front
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline   Reply With Quote
Unread 06-27-2012, 02:58 PM   #5
bmlarson12
thanks, I was thinking of that, but it is good to know for sure that could work.
Unread 06-27-2012, 04:21 PM   #6
bmlarson12
Do I need to take the exhaust manifolds off to pull it out or not? Which would be easier?
Unread 06-27-2012, 05:47 PM   #7
bmlarson12
I can't figure out how the transmission connects to the engine. It's at the top of the transmission, right?
Unread 06-27-2012, 06:20 PM   #8
Kevinyj95
Yes the exhaust has to come off. Use a towel on the fender to lay the a/c on so you dont scratch the hell out of the car. The engine comes slightly forward then out. Dont just pull on it. you may have to tip the motor to get the top bolts out. dont bend your dust cover. Its funny to watch people start there car and think they have ruined there engine. But Ive been there.
Kevinyj95 is offline   Reply With Quote
Unread 06-27-2012, 06:34 PM   #9
Technohead
Old school
Technohead's Avatar
Sounds like you need a factory service manual.
Thankfully, I have never had to pull an engine from a ZJ but when removing engines I normally pull both the engine and transmission as a unit.
P.S. When you disassemble the engine you will almost certainly discover that the heads are cracked. I would recommend going with a remanufactured engine from a supplier such as Jasper. Much easier.
Technohead is offline   Reply With Quote
Unread 06-27-2012, 07:33 PM   #10
bmlarson12
Thanks, where and how do you think I should attach the engine block lift? and which one is the dust cover?
Unread 06-27-2012, 10:38 PM   #11
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I found it much easier to use a cherry picker and a floor jack. Use the cherry picker to hook up to the engine and pull the motor mount bolts. Then, carefully, using the floor jack to assist, drop the engine back down through the mounts to gain faster and easier access to the top of the transmission, the distributor cap and other electronics.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Unread 06-27-2012, 11:13 PM   #12
mrclark25
1994 ZJ
i would cam it and if you have the money, find some headers to put on it.
higher performing heads would also be nice, but i don't know of any.
|_|0|_|
|_|_|0|
|0|0|0|
mrclark25 is offline   Reply With Quote
Unread 06-28-2012, 01:07 PM   #13
bmlarson12
Hunter
Ok, I will try that to get the transmission and engine block apart. I think I have all of the electronics out of the back now that the intake manifold is off.
Unread 06-29-2012, 11:41 AM   #14
bmlarson12
So the engine is out, how much wear on the bearings would indicate that it was a problem? Some of the rod bearings have some copper exposed. Would that be able to cause a knock?
Unread 06-29-2012, 07:21 PM   #15
bmlarson12
What all could cause a deep knocking sound in the engine?
5.2l , engine rebuild , magnum , performance
