5.2l gasket question... - JeepForum.com
post #1 of 4 Old 06-28-2014, 11:21 AM Thread Starter
ozzy_2_me
1994 ZJ
Hey gals and guys.
I am doing the plenum pan gasket on my 5.2l and before I start the job I want to make shure I have EVERYTHING.
I noticed some guys are using rubber seals for the front and back for the intake to engine block. does anybody have a part number or know were I can get these?
I did try searching and all I can find are the cork ones.
thanks,
-Kevin
ozzy_2_me is offline
post #2 of 4 Old 06-28-2014, 11:45 AM
kg6mov
Hears the voices
kg6mov's Avatar
This fel-pro kit has the rubber ones. Used them on both my jeeps and has worked perfectly: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
http://www.jeepforum.com/forum/f13/k...l#post19732865
kg6mov is online now
post #3 of 4 Old 07-15-2014, 07:50 PM Thread Starter
ozzy_2_me
1994 ZJ
hey Man I am Sorry for the late reply I got major side tracked. I want to personally thank you for your help. that is he one I was looking for. the end seals in this kit are a lot better then the cork ones that come in the '94 zj 5.2l kit. I started this job at about 10am on the July 3rd. I wanted to make sure I had everything I needed so I would have to make that one trip for the one thing I needed to finish the job. and I ended up finishing right around 10.30pm the same day. I unfortunately had to deal with a stubborn EGR tube. Thank you once again.
-Kevin R. O'Connor
post #4 of 4 Old 07-15-2014, 07:55 PM
PolkaPower
I used a real thick bead of "Right Stuff" RTV in place of the rubber gaskets over 3 years ago.
If you are not careful re installing the intake, those end gaskets will shift and you will have to do it all over again.
PolkaPower is online now
