5.2L Advanced Engine Maintenance - JeepForum.com
post #1 of 14 Old 04-01-2010, 06:12 PM Thread Starter
amonostereo
School me on advanced engine maintenance for the 5.2L V8:
Start here: the valve covers have probably never been taken off, and I want to know what to replace and check when I do.
Not basic stuff like changing the oil... More stuff geared toward 'what to do to a 18 year old engine that has only ever had the oil changed'.
I want to go through the engine and do stuff like cleaning the valves but I don't know how to do that or what else to do while I am there.
I searched and couldn't find much, but if there is a writeup out there for this kind of stuff, please direct my attention to it! If you think that the Jeep community is in need of a writeup for something on this line of thought, let me know so I can do it (or try....)
Thanks guys!
'93 5.2L V8, Laredo, 242 TC swapped from a 249, 3" Coils up front and Front coils in the Rear, JKS Adjustable Track bar, K&N Cold Air Intake with Amsoil filter, Rear cargo area shelving, and KOR's Steering Gear Brace, IRO's Over-The-Knuckle Steering, Top Light Rail, Top Tire Carrier... for now...
OR If you prefer acronyms: 93 5.2 V8, 249>242, 3" FC, ~2" RC, JKS Adj. TB w/ KOR TB Bracket, K&N CIA w/ Amsoil filter, Shelves, KOR SB, IRO OTK HD steering
amonostereo is offline
post #2 of 14 Old 04-01-2010, 11:40 PM Thread Starter
amonostereo
How about somebody starts off with a simple, "How to properly clean your valves" or something....
post #3 of 14 Old 04-01-2010, 11:44 PM
kwellzz
Are you looking to take the heads off? Valves out? Replace springs?
Could pull the pan and do new bearings.
Many will run ATF fluid in the motor to clean sludge.
Replace trans filters.
Basically if it ain't broke, don't try to fix it.
Denver Motorcycle Repair
kwellzz is offline
post #4 of 14 Old 04-01-2010, 11:59 PM Thread Starter
amonostereo
I am just looking for stuff to do when I have the valve covers off. I agree with the if it ain't broke philosophy. i am mainly looking to replace some of the stuff that can wear out while I am in there anyway.
Maybe think of it this way: if you were to go through an old (but running) engine, what would you replace or clean.
Also, I want to keep the motor in the Jeep.
post #5 of 14 Old 04-02-2010, 12:12 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
none of the things you're thinking you can do will happen with just the valve covers off.
"advanced" maintenance would be tearing it down completely.
if you have a leak, fix it. other than that don't go digging around unless you've got 500$ or more and a couple weeks of your time to spare.(if you have the skills)
best thing you can do is check for a plenum pan leak, check your compression, do your proper tune up with plugs, cap, rotor, wires, filters, coil, fluids. clean your tb and iac. and make sure your ccv/pcv and egr aren't all fouled out.
cleaning valves requires removing the heads.
ratmonkey is offline
post #6 of 14 Old 04-02-2010, 12:14 AM
kwellzz
Truthfully not alot to do to a running motor. Maybe run some detergent(atf) in the oil. Maybe injector cleaner. Mostly the normal maintenance stuff is all I found necessary.
kwellzz is offline
post #7 of 14 Old 04-02-2010, 11:16 AM Thread Starter
amonostereo
Thanks for the input so far!
So cleaning valves requires removing the heads. Is it possible to remove the heads with the engine in? I am no longer considering this, I just want to know if it is possible.
I have done pretty much everything on that list. Is there anything else I should consider?
post #8 of 14 Old 04-02-2010, 11:26 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Yes the heads can be pulled with motor in vehicle. Don't even pull the valve covers if you don't have to. If there's no noise, leaks and the oil pressure is ok, you're good to go.
HighLonesome is offline
post #9 of 14 Old 04-03-2010, 12:34 AM
kwellzz
Do yourself a favor and don't use cheapo Fram oil filters or K&N air filters. Prevention is a great way to keep your motor running.
kwellzz is offline
post #10 of 14 Old 04-03-2010, 12:39 AM
HighLonesome
My Nissan 2.4 I4 has 215,000 miles with Fram filters and still runs strong.
post #11 of 14 Old 04-03-2010, 01:03 AM
kwellzz
Last I checked the Nissan 2.4 I4 wasn't put in an offroad vehicle.
kwellzz is offline
post #12 of 14 Old 04-03-2010, 01:14 AM
HighLonesome
You'd be surprised where I've taken that 2wd pickup.
You've lost a motor due to a Fram filter?
post #13 of 14 Old 04-03-2010, 01:19 AM
kwellzz
Hard to simply blame a filter. The op is interested in 'things' to do and seems to want some peace of mind. A better quality filtration system is not exactly steering him in the wrong direction.
Personally I have lost 2 motors. Both ran Fram oil filters but I'm not blaming Fram either. Not exactly an easily proven cause and effect.
kwellzz is offline
post #14 of 14 Old 04-03-2010, 01:28 AM
HighLonesome
Point well taken. I ran the cheap Fram filters because I didn't know any better. Now I run the more expensive Fram only because they have the grip surface for easy removal.
I love my Jeeps but you could probably run mud in a Nissan motor and get 100,000 mile out of it. The difference in quality build between my '94 Nissan hardbody truck and my '94 Limited ZJ is staggering. But which one do I love more and drive everyday?
5.2l , engine , maintenance , rebuild
advanced bulbs for LOW, HI, & FOG straty1987 ZJ Grand Cherokee Forum 8 10-15-2009 08:14 PM
Rustys 4.5 Advanced Kit asu4x4TA ZJ Grand Cherokee Forum 5 05-29-2008 08:02 PM
Rustys advanced kit for WJ? vwmaniacx ZJ Grand Cherokee Forum 27 05-18-2008 12:13 PM
advanced No Heat questions user jeep ZJ Grand Cherokee Forum 7 12-12-2006 01:00 PM
any one have Rustys ZJ 5.5" Advanced Kit thechampion ZJ Grand Cherokee Forum 13 02-20-2006 11:30 AM
